PT-Dave 2003 Cranberry Turbo GT ![]() Stage I, custom 3\" exhaust & Cowl Intake, Mopar BOV, Dual gauge pod w/vac-boost & A/F meters, Hood Struts, Yokohama ES-100\'s Best 1/4 so far: 14.489 @ 93.65, best 1/8: 9.222 @ 74.261 |
If the tranny and halfshafts are out of the way, the sky is the limit. The stock turbo with everything tweaked to the moon is good for a little less than 300bhp. Stage II has 3 bar (heh) MAP and TIP sensors which will let you run to 30 psi of boost. People are making north of 300 ft-lb with 18 psi. You do the math.
Stage III is the next step, as Stage II runs out of turbo. The Stage III turbo can flow about 50% more air....
PT GT - Fastest damn lease car I could hope to have... |
At what point does the stock turbo cross the line where increasing the boost isn't efficient anymore? You know, because it begins to blow hot air?
\"If I had a diesel rig, with a big ol\' blade, courtesy would reign, arguments abate, cuz everyone would know, I\'d SQUASH \'EM LIKE A GRAAAAAPE!\" -- Heywood Banks, \"If I Had a Bulldozer\"
Depends what you mean by efficient. All turbos have a 'choked flow' point where it doesn't matter what you do they won't flow any more (see above for stock limit). If you force it (hard to do), you can overspeed the turbo and usually the turbine separates from the shaft and dies a horrible death.
\'03 GT Cruiser,White w/ Auto Stick, MOPAR Stg. I, AirAid intake,Alpine XM radio w/ 4 MBQuartz, Autometer Lunar Boost and A/F Gauges \'02 Corvette (510 RWHP/510 TQ) Member of 11sec. club & NRA Benefactor Member |
Hey guys/gals...I don't think you realize how great our little 2.4 turbo-engine is. My wife is interested in the Mazda RX8 so we recently took one for a test drive. This thing is rated at 250 HP at 8500 RPM (redline is 9,000 RPM!) in the manual version (auto is rated at 210 HP). We took it out for a test drive and the salesman told her to "go for it"...I asked her twice if she had the throttle all the way to the floor because it didn't even compare to our GT's when the turbo kicks in. When we got home I looked at the brochure and their engine is only rated around 160 ft. lbs. torque! The RX8 would whip our a** in the twistys but give me my GT at any stoplight.
I'm talking her into test driving a SRT4 next... Deen
GT, 5-Spd, K&N filter, Stage I, AGP 3147 Big Turbo, DTEC Fuel Kit, Tial WGA, Greddy Profec EBC, DCR 55mm TB, 05 Plastic Manifold, 180 Deg. Stat, CCA FMIC, AMX hard-pipes, Water-Injection, STS shifter, Needswings 3\" DP w/dump and Borla Cat-back, BG Drop Springs, Eibach Sway Bars, Panther alloys & Eagle F1 Max-Performance Tires. Best run to date...12.93 @113.45MPH. 77 Blown Vette-runs 10\'s @ 136 MPH. |
Just curious.
2003 GT Turbo, 5 Speed, Patriot Blue, Stage 1 |
crazyjoe:
Most modern turbo compressors can run about 3 to 1 pressure ratio at about 60% of peak flow. So if your wastegate is shut and you are providing enough power to spin the compressor up high enough, you multiply the turbo inlet conditions by 3. At peak torque, which is roughly 60% peak flow - air cleaner depression is about 3 psi vacuum, so 12 psi absolute * 3 = 36 psi. Therefore the turbo can make about 21 psi boost. However, at peak flow the max pressure ratio line drops to around 2.5 to 1. With air cleaner depression down to 10 psi absolute, only 15 psi boost is available. The compressor map is bounded by the maximum compressor speed at the top and max flow on the right. Usually these edges represent around 50% compressor efficiency - which is really poor. Going off the edge of the map usually also means overspeeding. You can see in order to maximize the use of a compressor, you need a wastegate solenoid running the boost level - because a manually-controlled fixed boost level would try to overspeed if set too high. Bigger diameter compressors can achieve about 3.6:1 pressure ratios or better, however they are just too huge to be used on passenger cars where driveability is important. TurboDanny: Yes. Torque converters multiply torque, so we have to reduce boost in first gear. The Getrag has skinny first and fifth gears, so torque is reduced in those gears as well. First isn't so bad because you can still easily spin the tires even at the reduced boost. Fifth, well you should downshift...
Hey there 3BarBoost, I've been reading all the posts about boost, and returning to stock levels. Something I read years ago stated: every 3 PSI of boost, equals close to ONE compresion ratio increase. So in reality, our 8.1 (or so) compresion ratio jumps to 13.1 at 15 PSI. And I'm sure we all know that a high compresion engine NEEDS high octane fuel, weather N/A or forced induction, does this sound pretty acurate to you???? Stew
\'04 GT w/auto stick, tinted, remote start, boost guage, BTG exh.,seatcovers, armrests,sunroof,......... |
| Stage II for PT is here! | skripo | General Turbo Discussions | 9 | 12 May 2008 09:11 pm |
| Stage I boost levels? | ptgtcb | Stage Turbo Kits | 9 | 16 Feb 2004 09:26 pm |
| Stage 1 boost levels | OurPTGT | Stage Turbo Kits | 3 | 22 Nov 2003 12:01 am |
| Max boost for stock GT | knowyourturbo | Stage Turbo Kits | 23 | 02 Oct 2003 06:11 pm |
| Final manual boost controller installation | Ian-PT-GT | Turbo Performance | 83 | 10 Jul 2003 11:57 pm |
