| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
Have Stage 1 installed for eight weeks
the boost has gone back to stock levels, have checked every thing. Called Mopar Ralph will call back A.M. My wife drives it every day did it learn her driving style? I'm not pleased. |
IS YOUR CAR A MANUAL OR AUTOSTICK?
Patriot Blue 5-Spd, Stage I, Mopar BOV, BTG Intake, Custom 3\" Turbo-Back, Spring Mod, BTG Shock Tower Brace, Vogtland Springs, Koni Shocks, Eibach Sway Bars, Azev Type M 18x8.5 wheels, Ventus K104 tires, Projector Bi-Xenon Lights, Rear spoiler, Autometer Gauges, Illuminated sill plates, K&N Oil Filter, Mopar subwoofer. Mexico City. See pics: http://www.sportcarsforum.com/forum/viewtopic.php?t=715 |
Autostick
culprat@sbcglobal.net |
Is it slower? Colder temps outside do lower boost, as the air is more dense. Goal is torque here, which isn't the same as boost. Total airflow commanded from the controller attempts to remain the same.
It's 45 here in michigan today, my car makes 11 psi.
PT GT - Fastest damn lease car I could hope to have... |
When I did the install it carried 15.25 pound of boost
to 6000 then droped to 10.5 pounds at the shift,at shift completion it went back to 15.25 until you let off the loud pedal. Torque is down also three turn of the tires at launch. Yes it is slower!I know it's 45 I live in battle creek, something is not right. Ralph from Mopar didn't return my call ether.
[/quote] When I had my oil changed on Friday I asked if flashing the computer would mess up my Stage 1 computer, like for instance fuel management. I was told that it would not take me back to stock. 3BarBoost, MEXICANPT? Truth or fiction?
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
The dealers do not have the ability to d/l stage1 so they would be d/ling the basic program which would mess up your pcm. This is in my opinion!
LIP
2003 Electric Blue GT 5 speed loaded |
I can't diagnose with no info.
The wastegate spring will only allow 10-12 psi over 4500 rpm.. This is normal..You can make 18 psi but after 4500 it will bleed to 10-12. Unless you change the gate. Ps, any dealer flash will render you stage I a spare factory PCM....:-(.....(the fuel map will change).
PTTURBINE Toronto 13.48@105.36 |
Nothing has changed from the time I installed the kit ever thing was fine until last monday.
I think you are wrong about boost dropping off, because this would carry 15.25 all the way to 5600 and drop off to 12.5 at the shift and once it shifts in to overdrive it would pull until you run out of nerve. It has lost alot of the torque it had at that time,I have checked every hose and line for leaks and come empty,that's why I the post.
| Stage II for PT is here! | skripo | General Turbo Discussions | 9 | 12 May 2008 09:11 pm |
| Stage I boost levels? | ptgtcb | Stage Turbo Kits | 9 | 16 Feb 2004 09:26 pm |
| Stage 1 boost levels | OurPTGT | Stage Turbo Kits | 3 | 22 Nov 2003 12:01 am |
| Max boost for stock GT | knowyourturbo | Stage Turbo Kits | 23 | 02 Oct 2003 06:11 pm |
| Final manual boost controller installation | Ian-PT-GT | Turbo Performance | 83 | 10 Jul 2003 11:57 pm |
