Hey 3BarBoost
Old 05 Oct 2003, 12:25 am
Send a message via AIM to Herschel
Default Hey 3BarBoost
How can I contact you directly? I wrote in
another post but I guess you didn't see it.
Herschel Irons
E-mail address: jessiebell@voyager.net
1 517 487-5308.
Old 05 Oct 2003, 02:29 pm
You can send me a PM at neons.org. I don't give out my contact info, sorry...
PT GT - Fastest damn lease car I could hope to have...
Old 05 Oct 2003, 06:44 pm
3Bar:
Just wanted to drop you a quick not to tell you how much I appreciate your informed input. I hope you will continue to provide us with your informed perspective on a variety of performance issues. Your experience is quite valuable in deriving the most pleasure from what I believe to be a well designed vehicle with incredible stealth performance potential.
Thanks for all your help.
P.S. I was able to find a 180 hp turbo for my son for less than $20,000. Have ordered the Stage 1 for him and really look forward to seeing the results.
03 GT, Stage 1
Race Pipe and custom 3\" back, Eibach Springs, A Pods with EFT and Boost, MP Underdrive Pulley, 180 thermostat, Taylor Racing Wires, NX wet Nitrous 50 shot for quick spool/hp with msd tac drive and window switch, Mopar BOV, FIPK intake, APC Euro Tail Lite Kit, all badges removed.
Old 05 Oct 2003, 08:05 pm
PM ? Sorry??? So to contact you I just need to
address an e-mail to neons.org att: 3BarBoost?
As my friend FRM3 already posted-it is great to
have someone with first hand information. But,
(as you said before) correct me if I'm wrong,
some pointed direct questions would have to
be hedged and inferences drawn, correct?
Again, Thanks 3BarBoost. H.
Old 05 Oct 2003, 09:45 pm
PM = Private Messege
You need to go to neons.org and look him up on their site forums to send him a PM (instant messege) through their site.
Old 06 Oct 2003, 10:28 am
3BarBoost,
Sometime back in one of your early post you asked what we(the poeple on this site wanted) will if I could access the data that is running real time in the pcm I could find out what is going on. Just a thought, thanks for all you have posted.
culprat@sbcglobal.net
Old 06 Oct 2003, 06:42 pm
What he said. Understand that as part of my contract with DCX there are many matters I just can't talk about (like getting data off the the engine controller). On the other hand, I can help with a large variety of other subjects - particularly if you are having troubles understanding how things work, or why some upgrades are better than others.
Old 06 Oct 2003, 08:09 pm
3BarBoost:
I am glad to have clear explanations of how things work and what particular upgrades will actually make a difference (after reading your posts I did not change air intake).
When installing the stage 1 kit on my sons 04 SVT is there anything we should do not covered in the Stage 1 directions? ( In that Stage 1 directions assume GT rather than SVT)?
I am also curious as to tires (brand, size) you consider helpful for greater launch traction.
Thanks
03 GT, Stage 1
Old 06 Oct 2003, 10:49 pm
The results of installing a Stage 1 on a SVT might be a little unpredictable - on the trans side. I really don't know what would happen if you stuck it in other than P,N,R or D. Might experiment a little - at least putting the production controller back in is easier than in a Neon. Because of that, a Stage 1 is cake compared to an '03 install. Unplug one controller, plug the other in.
As for tires, if you don't mind getting new tires every 10k miles there are lots of better choices than the GSAs. Depending on where you live, you might be able to tolerate a three-season tire (which means 'suck in snow') - you will be talking another set of wheels with snow tires however. The SRT stock tires, BFGoodrich G-Force KD or KDWs are pretty awesome - at the other end of the spectrum Nitto and Kumho are cheap, but the stickiest tire I have experienced recently was the Michelin Pilot Sport Cup (a DOT-labeled slick). About the biggest tire I have seen fit is a 235/45-16 (yes 16). Keeping in mind I spend most of my time on road courses as opposed to the strip. Visit Tire Rack and look around....
Old 06 Oct 2003, 11:00 pm
Without the autostick I see no reason to use 1 and 3. Shift points should be fine with D. Greater concern is that Stage 1 HP becomes available. Would you assume D would be solid?
Live in Houston so I don't need Winter tires. I'll take a look at the BF Goodrich options and the Michelin is intriguing for the strip.
Thanks
03 GT, Stage 1
3BarBoost, You said you could help us w/S2 Mods... hyracer Stage Turbo Kits 11 04 Mar 2004 08:56 pm
3barboost: exchnage pcm? insane1 Stage Turbo Kits 14 28 Feb 2004 01:20 am
question for 3barboost tthrift Stage Turbo Kits 16 23 Feb 2004 10:12 pm
Mopar Cat-Back...Calling 3BarBoost hyracer Turbo Performance 10 04 Dec 2003 07:29 pm
Met 3BarBoost and UniqTwin at Block Party skylight General Turbo Discussions 5 25 Nov 2003 06:32 pm
