Stage 2 info from SRT-4 site
Old 07 Nov 2003, 09:00 am
Default Stage 2 info from SRT-4 site
Got this from the SRT site, hope they don't mind!
In the Mopar brochure I recieved this is what is said WORD FOR WORD (there are no pictures of the stage 2 or 3 uprades int he brochure).
STAGE 2 TURBO UPGRADE KITS --- SRT-4 AND PT TURBO
The Stage 2 Turbo Kits for the SRT-4 and PT Turbo give you a power boost of 265hp and 280ft-lbs. of torque on premium pump gas. For SRT-4, you can also achieve 280hp and 300ft-lbs. of torque on 100+ octane unleaded racing fuel. For additional power and a more aggressive exhaust note, you can add our new Cat-Back Exhaust System (see page 26 for details).
*Stage 2 PCM
*Turbo toys (SRT-4 only)
---Turbo Intercooler Sprayer
---High Octane Fuel Switch
---Dial-A-Boost "Down" Switch
---All necessary wiring, switches and mounting hardware
*(4) 682cc/min fuel injectors
*Wastegate actuator
*3.0 Bar Map Sensor
*3.0 Bar TIP Sensor
*P5007863 2003-04 SRT-4 Stage 2 Turbo Upgrade Kit
*P5007946 2003 PT Turbo Stage 2 Upgrade Kit --- MTX
*P5007945 2003 PT Turbo Stage 2 Upgrade Kit --- ATX
*P4510257 2004 PT Turbo Stage 2 Upgrade Kit --- MTX
*P4510258 2004 PT Turbo Stage 2 Upgrade Kit --- ATX
STAGE 3 TURBO UPGRADE KITS --- SRT-4 (late availability)
For maximum power and torque --- target is 300hp/300ft-lb. of torque --- Stage 3 Turbo Kit is the ultimate upgrade for your SRT-4. Includes all Stage 2 components plus the following upgrades:
*Stage 3 PCM
*TDo5HR-15k2-10cm2 (2 is for squared) turbo unit
---16% larger compressor wheel diameter to flow and compress more intake air
---19% larger turbine wheel diameter to flow more exhaust gas and reduce back pressure
---67% more turbine scroll area for reduced back pressure
*High-flow (75 psi) fuel pump module
*Demand-regulated fuel rail assembly
*P5007864 2003-2004 SRT-4 Turbo Upgrade Kit
*P4510256 2003-2004 SRT-4 Stage 3 Add-on Kit (for vehicles with Stage 2)
Old 07 Nov 2003, 09:38 am
tthrift,
Prices please on the PT Crusier S2 kits. Also info on the new Mopar Cruiser cat-back exhaust (pipe diameter, muffler or no muffler, resonator, etc.) and your pricing for our PT's?
3BarBoost, is this a way early release that is going to be changed...or didn't they hear us on the "Turbo Toys" survey? By my count there were more requests for keeping the "Toys" than those who just wanted the no-frills deal...
Deen
Old 07 Nov 2003, 09:39 am
Thrifft!
Any chance if these part numbers are doable please put in an order for stage II for me!
Moondoggie!
Jeff Taylor
AKA: Moondoggie!
moondoggie@kingwoodcable.com
Founding Director
Houston City Cruisers
www.houstoncitycruisers.com
Old 07 Nov 2003, 10:31 am
Send a message via AIM to macster
Yeah, I saw this also. I wonder what we have to do in order to get the Stage 3 Turbo to work on our cars? I sure could go for the additional HP provided by the larger Turbo.
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
Old 07 Nov 2003, 05:06 pm
Mopar does not list this numbers yet on its system.
Patriot Blue 5-Spd, Stage I, Mopar BOV, BTG Intake, Custom 3\" Turbo-Back, Spring Mod, BTG Shock Tower Brace, Vogtland Springs, Koni Shocks, Eibach Sway Bars, Azev Type M 18x8.5 wheels, Ventus K104 tires, Projector Bi-Xenon Lights, Rear spoiler, Autometer Gauges, Illuminated sill plates, K&N Oil Filter, Mopar subwoofer. Mexico City. See pics: http://www.sportcarsforum.com/forum/viewtopic.php?t=715
Old 08 Nov 2003, 10:42 pm
Availability is still several months off, so the part numbers being publicized is a bit of a surprise for me. Also, since there is no pricing info - makes me suspect this is some spy data as pricing is published concurrently with part numbers.
TurboG was at SEMA this last week, so she hasn't had a chance to discuss with her team the results of my survey. Things could easily change in the next few months...
PT GT - Fastest damn lease car I could hope to have...
Old 09 Nov 2003, 06:53 pm
Send a message via AIM to Black04Turbo
is there any idea when the stage 2 will be avail... and if it is gonig to worko n my 180 hp PT? I couldjust hold off on the stage 1 and get the stage 2 if so [?]
My Goal:
Send a message via AIM to sakigt
Mopar guy at SEMA said $1000-$1500 and they STILL dont know what will be included in Stage 3
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
Old 13 Nov 2003, 09:33 pm
stage 2 or three will it void the warrenty??
Old 14 Nov 2003, 01:33 am
bob opening a can of worms?
Stage II for PT is here! skripo General Turbo Discussions 9 12 May 2008 09:11 pm
stage II info tthrift Stage Turbo Kits 21 10 Mar 2005 11:59 pm
Current Stage 2 info (SRT) SDTurbo Stage Turbo Kits 14 22 Apr 2004 11:25 pm
Mopar Web site - Stage 2 gone?? dtbrks Stage Turbo Kits 19 17 Mar 2004 12:08 am
stage II kit info tthrift Stage Turbo Kits 44 28 Dec 2003 09:02 am
