# Bar Boost comment:
especially since certain OBD functions were shut off to make it easier for you to increase performance if you so desire. It would be of interest to know specifically, which diagnostic functions are removed or turned off in the PCM for the Stage I and Stage II kits. Facts would be easier to digest than conjecture. |
The graphics are missing, but this is a snapshot of the Telemetry OBD monitoring readings.
Diagnostic Measurements as of 11/17/03 09:58 PM MIL Light (OBDII Data) off Ignition Timing Advance (ATDC) (OBDII Data) 6 deg Battery (on) 14.2 V Battery (off) 12.5 V Calculated Load Value (OBDII Data) 4.7 % Engine Speed (OBDII Data) 766 RPM Engine Coolant Temp. (OBDII Data) 199 degF Intake Air Temp. (OBDII Data) 77 degF Abs. Throttle Position Sensor (OBDII Data) 14.9 % Short Term Fuel Trim, Bank 1 (OBDII Data) 1.6 % Long Term Fuel Trim, Bank 1 (OBDII Data) -4.7 % Fuel System Status/B1 (OBDII Data) closed Intake Manifold Abs. Pressure (OBDII Data) 41 KPa Oxygen Sensor Location (OBDII Data) B1S1 B1S2 Bank 1 Sensor 1 Fuel Trim (OBDII Data) 0.8 % Bank 1 Sensor 1 Voltage (OBDII Data) 0.605 V Bank 1 Sensor 2 Fuel Trim (OBDII Data) 100.0 % Bank 1 Sensor 2 Voltage (OBDII Data) 0.075 V OBD system type (OBDII Data) 3 Keyon time 945 sec Run time 1378399 sec Resets |
All those will show up fine, except maybe downstream oxygen sensor (bank 1 sensor 2). And I stress maybe. The fuel trim of 100% doesn't seem right, it should be less than the upstream value (0.075 volts versus 0.605) - so maybe that telemetry thing is already giving out faulty info.
The one OBD monitor that I know is shut off with Staged kits is the P1188 code (part throttle TIP overboost). This keeps us from getting the EO number. Trying to find out what else is shut off, if anything.
PT GT - Fastest damn lease car I could hope to have... |
This is the California list (all that the state will ever require of my PT for as long as I own it), so maybe we can squeek through anyway. Thanks for all your help!
| Stage II for PT is here! | skripo | General Turbo Discussions | 9 | 12 May 2008 09:11 pm |
| "Stage Turbo Forums" Killed by Mopar | hyracer | Stage Turbo Kits | 20 | 28 Apr 2005 04:26 pm |
| Tour de Lance STAGE 13 UPDATED | PTRON | Non-PT Discussions | 1 | 18 Jul 2004 09:02 pm |
| Tour de Lance STAGE 7 | PTRON | Non-PT Discussions | 0 | 10 Jul 2004 07:13 pm |
| Stage 2 info from SRT-4 site | dtbrks | Stage Turbo Kits | 24 | 26 Nov 2003 05:24 pm |
