OK Folks - Since S1 installation 4 weeks ago, I have had 2 transmission hoses go on me. The first was the small hose going to the front cooler. This went the day I had the Stage 1 installed. The second, yesterday going to work. Don't know exactly which hose went bad, have not been to the dealer yet to see it myself - just what he told me and I know it wasn't the same hose that went earlier. Has anyone had any problems like this. Any guess if this might be related to the Stage 1. I don't think so but wanted you opinions.[xx(]
Well - Just picked up my car and found out that the hose was the same hose that went on me the first time.[xx(][xx(] |
i wonder if you did the tranny quick learn procedure?
![]() \'03 GT Inferno Red AutoStick - Stage 1 - Air Box Mods & K&N Filter - AMX Intake Down Pipe - Flowmaster 40 Series Exhaust - Magnacor 8.5mm Ignition Wires - Pin Stripping - Chrome Side Spears - Chrome Tail Light Covers - Chrome Fuel Door - E&G Custom Grill - Painted Rear Mud Guards - 3-D Liquid Flames - Chrome/Red Neon Washer Nozzles - Interior Neon |
mich_132003,
I reported this phenomenon a while ago. While changing my oil, I noticed that the transmission cooler line on the left side of the radiator (when viewed from the bottom of the car, looking to the front) was coming loose. My theory is the line is very close to the oilpan. When you rev the motor, the engine torques (moves) a bit. The torquing is making the line come loose. Just a theory... Sounds like a safety item to me.... Scott
\"If you choose not to decide, you still have made a choice.\" |
"Sounds like a safety item to me...."
very true!! |
Sounds like a failure directly related to the install of a part that is not authorized by DC or warranted by DC, you know, that renegade MOPAR division. Per their written warranty statement, you are on you own...rediculous ain't it?
This doesn't sound like the same hose you reported on. Is it possible the added torque (engine kickback) is ripping the hose? If so, more slack in the hose should help. I'm surprised, if this is related to Stage 1, that others are not having the problem. Lou
The computer controls line pressure in an auto trans. There should be a pressure relief valve but if it is malfunctioning or the computer is not getting the right input from sensors or the computer itself has problems you could be running too much pressure. However this will usually result in much harder shifts too, you did not specify this as a symptom
The pressure in the system will not be released by the "dipstick lifting". The only pressure that this will release is internal case pressure which really doesn't happen much (unless for some reason your fluid is really getting aerated, which could indcate an iternal probem). The dipstick is not part of the high pressure system. It WILL NOT relieve excess line pressure. Do not accept this explanation from the dealer. Dealer is just trying to get you to leave them alone. If the computer is for some reason bumping up the line pressure and it shouldn't be, you could be heading for problems with internal seals. You dealer or a good tranny mechanic can measure line pressure and tell you if it is our of spec. Then it is a matter of tracking down the cause.
I had two transmission cooler lines burst about 3,000 miles apart (the first at about 15k and the second at 18k). Thus far, I have not had any other problems and I am at currently at 22k. Please note that I do not have the Stage 1 upgrade. They could not tell my why it happened or what caused the second one to rupture after they inspected them while fixing the first. But my dealership was prompt in fixing the problem.
2003 Inferno Red GT Cruiser - autostick; Spoiler; Chrome fender trim and door spears; PT door lock pulls; \"turbo\" 3rd brakelight; green LED windsheild washer lights and license plate bolts |
| Stage II for PT is here! | skripo | General Turbo Discussions | 9 | 12 May 2008 09:11 pm |
| transmission problem after rear-end accident | dalipardon | Tech & Performance Forum | 12 | 05 Apr 2007 12:26 pm |
| Transmission downshift problem | Floyd Harris | Tech & Performance Forum | 5 | 05 Jul 2006 07:18 am |
| stage 1 install problem | gooberff | Stage Turbo Kits | 6 | 29 Jun 2005 12:22 am |
| "Internal Transmission Problem" ??? | yobiebs | General Turbo Discussions | 18 | 21 Oct 2003 11:17 pm |
