Stage 1 time question
Old 29 Nov 2003, 07:33 am
Default Stage 1 time question
I purchased the Stage 1 several months ago and, as you know, I had to report the mileage and VIN when I purchased it. I had 39,000 miles on it which was reported to the dealer at time of purchase. Now I have over 48,000 miles and I'm only just now installing it. Is there a problem with that? Why is the mileage an issue with the Stage 1?
Thanks.
Old 29 Nov 2003, 08:09 am
Send a message via AIM to tthrift
the millage isn't an issue, when chrysler set up the ordering system for the stage I kits that require the vin# for the sentry key to work. they used an ordering platform already in use, called function 11 exchange ordering. which i use to order replacement radios that need repair under warranty. the millage is required for a radio repair.
since they use the same ordering platform we must fill in all the prompts and the millage is one of the prompts.
i hope i have answered your question.
thanks tommy[8D]
Old 29 Nov 2003, 08:22 pm
tthrift, thats not my understanding of this issue, the pcm holds the milage for the odomoter, if you "lie" to them when ordering stage 1, you essential roll your odo back.
and I'm sure they can back trace your last repair to get the milage, if you should happen to make a big lie : )
punch
Old 30 Nov 2003, 02:49 am
The PCM does NOT hold the mileage for the odometer. I'm not 100% sure where the mileage is held (my guess is the odo. cluster) but I can tell you it is NOT in the PCM.
How do I know this? Well, I just installed my Stage 1 last weekend and the vehicle mileage stayed the same. When I ordered my Stage 1, I gave the correct odometer reading for the time, 6500km. I now have just over 9700km on the clock and that is what the odometer reads.
Marc
2003 PT Cruiser GT Turbo, Silver
1985 Dodge Omni GLH Turbo 16V, Black
http://connect.to/YBT
Old 30 Nov 2003, 02:52 am
GLH is right, in that the PCM doesn't hold the mileage for the Cluster. However, both the PCM and the Cluster read the vehicle speed signal and keep track of it separately....
PT GT - Fastest damn lease car I could hope to have...
Old 30 Nov 2003, 05:23 am
Thank you very much.
Old 30 Nov 2003, 04:26 pm
very good, forgive me all : )
good to know the car has otherways to track you isn't it?
Old 30 Nov 2003, 04:28 pm
and your happy with the stage 1, we want info my cdn brother......
Old 30 Nov 2003, 07:24 pm
The Stage 1 is great! I installed it last weekend along with the red valve cover and the power increase is very noticeable, especially in 1st gear. With the Trac Off, you can blow away the front tires anytime in 1st gear(Autostick car). I also noticed that the Mopar BOV sound has changed slightly. It is not as harsh or abrupt sounding, the sound is softer and longer if that makes any sense. I also really like the higher shift points, 6300RPM now vs. 5800RPM stock. I haven't done the quick learn procedure for the transmission yet so I can't comment on that. I've been driving it around town in Autostick for the past week.
Marc
Old 30 Nov 2003, 11:00 pm
LAF LAF is offline
GL you better read your S1 paper work. If you are doing WOT 6300 rpm shifts you are risking issues with trany. You can run it without quick learn but not WOT. Read your quick learn page in your S1 kit
Just trying to help............
The recipe for perpetual ignorance is: be satisfied with your opinions and content with your knowledge.
Elbert Hubbard (1856 - 1915)
2003 Electric Blue GT-30,000 Miles on the clock
Stage 1, Greddy Profec II B. Turbo Chargers Wastegate set to 13#. Forge Motors BOV (Blue of course). Brand AMX Intake/AirCooler Pipes/K&N Cone with Snorkel to Fender well, MSD Coil, Live Wires(Blue of course), Factory rear sway bar, KYB struts and shocks, BTG strut tower brace, Suspension Techniques 1.3\" F/R lowering springs, ATP 3” down pipe with high flow cat, BTG axle back exhaust, Rear Spoiler. Russel Brake Lines/Hawk Brake Pads/Power Slot Cyro Rotors on a four corners
Support Your Right to Arm Bears
Stage 1 question stranger Stage Turbo Kits 1 01 Sep 2006 07:59 pm
Another Stage 1 Question PTSleeper Stage Turbo Kits 2 05 Nov 2004 06:08 pm
HELP Stage one question scottscars Stage Turbo Kits 4 11 Aug 2004 08:29 am
Stage 1 kit question DREAM2 Stage Turbo Kits 5 17 Apr 2004 10:59 am
Stage 2 Question Mean Green Stage Turbo Kits 10 20 Mar 2004 07:54 pm
