DYNO RUN
  #21 (permalink)
Old 03 Jan 2004, 05:51 pm
quote:Originally posted by macster
Flash
NP, but I have a problem with the graphs they don't match my readouts per say. The fine divisonal graduations in the graph don't make sense. By this I mean the coarse divisions are in increments of 50, and the fine divisions should be in increments of 10 each. Take a look at the 256 Trq figure it should be 280 which matches my readout chart e.g. baseline lean. But from looking at it, the max Torque was 256ftlbs, other than that I'm okay with it. It appears that I wasted money on the 2.5" exhaust so far, or it may have accounted for the reason that the K&N added so much.[:I] My plugs were gapped at .048 I took them out they were all gapped at .050. FYI changing the plugs is scary, because of that sensor on the LH (facing the car) of the manifold, and that sensor that goes into the turbo airpipe.
macster
Yeah, be careful of that MAP sensor, or chanigng your plugs will get about 40 bucks more expensive. My advice is to remove it when changing the plugs....I broke mine the first time I did a plug change. It comes out pretty easy with 2 torx bolts, and then you just put it back in when you're done.
\"If I had a diesel rig, with a big ol\' blade, courtesy would reign, arguments abate, cuz everyone would know, I\'d SQUASH \'EM LIKE A GRAAAAAPE!\" -- Heywood Banks, \"If I Had a Bulldozer\"
  #22 (permalink)
Old 03 Jan 2004, 06:14 pm
Send a message via AIM to macster
[/quote]
[/quote]
You ain't really crazy, that's good info. That thing has break me all over it. I got a set of torx tips from Sears when I was picking up the Old Folks tools box, the tips cost me $8.00. And the first thing that I used them for was to remove the MAP sensor so that I could get to the plugs.
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
  #23 (permalink)
Old 03 Jan 2004, 07:24 pm
What was the source of your vacuum leak and what is your macster mod? Thanks
  #24 (permalink)
Old 03 Jan 2004, 08:30 pm
Re"What was the source of your vacuum leak and what is your macster mod? "
Operator error
Re"what is your macster mod?"
Someone told me to
"yep grab the wastgate and crush the can and bend the rod, and let us know what happens"
And that's what I did, and it guess what it worked. Go figure!
macster
I changed the closed end cone on the K&N to one that is open ended, this allowed me to get the cone end closer to the opening in the wheel well. AMX137 is on to something with his CAI, I would like to get the dyno figures with his CAI installed.
Don\'t help me
Help the bear
  #25 (permalink)
Old 05 Jan 2004, 08:32 pm
Here is the link to results from the K&N dyno chart on the PT GT typhoon http://www.kandn.com/dynocharts/69-2541TP.jpg
Note the RPM range where the graph starts and where the HP gains are and are not. The most obvious questions are,
Where are the torque numbers and what are they?
Why don't they show what the HP and Torque gains are at the lower RPMs?
On the other hand AirRaid shows both HP and Torque figures. http://www.airaid.com/images/300-138-dyno.jpg (6 HP gain and 18ft/lbs) of torque and most importantly the gains are linear from the low end through the mid range.
comments
macster
Don\'t help me
Help the bear
  #26 (permalink)
Old 05 Jan 2004, 09:40 pm
You might take a look at the dyno chart for K & N FIKP on the PTGT ---- even more to ponder with Gains from about 3650 to 5800 -5900. In fact traction being the issue that it is, if the primary gain is midrange to upper end that suits me better.
http://www.kandn.com/dynocharts/57-1531.jpg
03 GT, Stage 1
Race Pipe and custom 3\" back, Eibach Springs, A Pods with EFT and Boost, MP Underdrive Pulley, 180 thermostat, Taylor Racing Wires, NX wet Nitrous 50 shot for quick spool/hp with msd tac drive and window switch, Mopar BOV, FIPK intake, APC Euro Tail Lite Kit, all badges removed.
  #27 (permalink)
Old 05 Jan 2004, 09:52 pm
Send a message via AIM to ZZCruzr
macster....thanks for all of the info. and time in sharing! I don't have Stage 1 yet, so this is good stuff!
[IMg]
http://fototime.com/{5590095C-9F94-449F-A156-7F9FD8C700EB}/picture.JPG[/IMG]
Black Clearcoat 2003 Turbo GT w/gray leather interior...rear splash guards, stainless door sills, air bag decals, red painted brake calipers, BTG duals, AMX cold air intake, Blaine hood struts, ZZcruZr third brake light diffuser, AutoVation pedals, MoMo F16 Evo red gearshift.
  #28 (permalink)
Old 05 Jan 2004, 10:09 pm
FRM
At 5002RPM
My Baseline PTGT 183.5HP 220 Ftlb torque
K&N Typhoon 185.7 195 Ftlb torque
Macster MOD 196.5 203 Ftlb torque
FPIK on their Base Line PTGT 192.5HP no Torque figures provided on the Dyno Chart. If we take these HP readings as being true, then the FPIK gives you Stage1 like benefits for $233.00
It would be interesting to get real world results with FPIK. I think that IAN-PT is buying one maybe he will give us the scoop.
macster
Don\'t help me
Help the bear
  #29 (permalink)
Old 05 Jan 2004, 10:13 pm
Macster:
I have one on order that should be here on Thursday or Friday. More info when it gets here!
03 GT, Stage 1
  #30 (permalink)
Old 05 Jan 2004, 11:02 pm
Macster:
Cool, it will be interesting to see how it works with your car. Do you have a boost gage installed? If so could you note if there are any changes in your boost with FIPK installed? BTW,I will be checking on drive axle and tranny upgrades $$$ I think that consistantly running low 13's and high 12's will cause problems in one or both of these areas and I want to see how much the fix will cost.
macster
Don\'t help me
Help the bear
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Evolution Performance Dyno Day - Saturday, 10/1 Evolution Northeast PT Forum 0 27 Sep 2005 01:12 am
Dyno Results for Hahn Turbo PT!! Ant Turbo Performance 7 09 Feb 2004 08:27 am
dyno danger 026TB4U General Turbo Discussions 0 11 Jan 2004 08:14 pm
Dyno #'s prior to Stage 1 install... rice_killing_GT Stage Turbo Kits 16 18 Aug 2003 08:51 pm
dyno results kruzzinpt Turbo Performance 2 28 Jun 2003 09:52 am
