I do have both boost and pyrometer and I will watch them closely. I am told the auto trans is good to 425 hp to 500 hp, sakigt made a similar observation. I have no idea about axles.
03 GT, Stage 1 Race Pipe and custom 3\" back, Eibach Springs, A Pods with EFT and Boost, MP Underdrive Pulley, 180 thermostat, Taylor Racing Wires, NX wet Nitrous 50 shot for quick spool/hp with msd tac drive and window switch, Mopar BOV, FIPK intake, APC Euro Tail Lite Kit, all badges removed. |
macster
Don\'t help me Help the bear Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe |
Comparisons to bone-stock is pretty much irrelevant: I would like to see a dyno of stock airbox with both silencers removed and a drop-in K&N, since it appears that is what most of us have done, at least at first. For those of us who fall into that category, the question is really about the plumbing. Would replacing the bends and the third silencer yield any gains? Since the Airaid does not do this, I would wager that the K&N drop-in sans silencers configuration would dyno identically to the Airaid. My guesses to the Airaid vs. Typhoon graphs: - Removing the silencers and using a better flowing air filter lessens the air restrictions enough to let more air in at sufficient velocities at the bottom end, but still too restrictive > ~4500 RPM - The Typhoon lets more air in overall, however, its unrestrictive nature does not generate sufficient velocity at the low end, but is perfect for the mid-upper end. Basically the same concept that applies to exhaust and headers, vis-a-vis 4-1 vs. 4-2-1. Does this sound right? |
Am I reading right per first chart that we start running lean after 13.9psi? So much for the 15psi myth...
![]() 14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!! |
macster
What I mean to say is that for most of us, "stock" is redefined as silencers removed with a K&N drop-in since that is what the performance-minded would do at a minimum anyway. |
[/quote] I think we have the same take on this, just semantics are a little problematic. What I mean to say is that for most of us, "stock" is redefined as silencers removed with a K&N drop-in since that is what the performance-minded would do at a minimum anyway. [/quote] Bro No problemo, I'm the one that talks and types funny. Okay, if that is stock then take compared RK's dyno readings to mine. He has the "stock configuration" and I have the K&N Typhoon. He dyno'd 200WHP. macster
I would be interested to see a followup dyno after the ECU relearns the lower intake resistance.
Will it drop the added 15 HP back down later, as 3 BAR says it will? |
| Evolution Performance Dyno Day - Saturday, 10/1 | Evolution | Northeast PT Forum | 0 | 27 Sep 2005 01:12 am |
| Dyno Results for Hahn Turbo PT!! | Ant | Turbo Performance | 7 | 09 Feb 2004 08:27 am |
| dyno danger | 026TB4U | General Turbo Discussions | 0 | 11 Jan 2004 08:14 pm |
| Dyno #'s prior to Stage 1 install... | rice_killing_GT | Stage Turbo Kits | 16 | 18 Aug 2003 08:51 pm |
| dyno results | kruzzinpt | Turbo Performance | 2 | 28 Jun 2003 09:52 am |
