PT Cruiser Forum Car Videos
Custom Wheels
DYNO RUN
  #41 (permalink)
Old 06 Jan 2004, 07:55 pm
Rolo Rolo is offline
Send a message via AIM to Rolo
quote:Originally posted by sakigt
But on the rest of the charts it seems to hold true... An A/F ratio of 10 is NOT agood thing
Oh, OK, I was wondering what I was missing with that. It was dead on 10.0, as if the computer were doing that intentionally..?
Do I understand it correctly in that you want 14.7 always?
  #42 (permalink)
Old 06 Jan 2004, 08:10 pm
quote:Originally posted by macster
No problemo, I'm the one that talks and types funny. Okay, if that is stock then take compared RK's dyno readings to mine. He has the "stock configuration" and I have the K&N Typhoon. He dyno'd 200WHP.
macster
haha, and I think abstractly and quickly...bottlenecking it all into words is a chore! That is one reason why I am so wordy.
I would like to collect everyone's tables and graphs and crunch them for proper presentation; why go through all the time and expense and not have it all compiled?
Your stock dyno was bone-stock, silencers and filter, with Stage 1 correct?
  #43 (permalink)
Old 06 Jan 2004, 08:25 pm
macster macster is offline
Send a message via AIM to macster
macster
yes
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
  #44 (permalink)
Old 06 Jan 2004, 08:39 pm
[/quote]
[/quote]
Okay
Explain, why is it bad and is the 10 lean or rich?
macster
Don\'t help me
Help the bear
  #45 (permalink)
Old 06 Jan 2004, 08:44 pm
[/quote]
Okay
Explain, why is it bad and is the 10 lean or rich in your opinion? The way that the chart reads is that the lower the number the richer the mixture and turbo have to run rich. Thats data that I have.
macster
Don\'t help me
Help the bear
  #46 (permalink)
Old 06 Jan 2004, 09:03 pm
Jason_L Jason_L is offline
I think some folks have this backwards:
10.0 is rich, the higher the number, the leaner the A/F.
an AFR of 10 means 10:1 air:fuel, compare that to 14.7:1 air:fuel..
looking at those a/f ratios, i'd say there's room for more boost
2003 Electric Blue GT
- Greddy E0-1, boost and AFR guages
- Custom exhaust: no muffler, side exit.
- Replaced air box with open end cone filter.
- Stage 1
  #47 (permalink)
Old 06 Jan 2004, 09:16 pm
quote:Originally posted by Kirby
I would be interested to see a followup dyno after the ECU relearns the lower intake resistance.
Will it drop the added 15 HP back down later, as 3 BAR says it will?
Kirby
I'm going to check in a month or so. The more I get into this the more I'm convinced that 3BaR and the PVO team know their stuff. We'll find if the ECU drops the HP down when I do another dyno run or if someone else does one. What I want would like to know is what ET should I be expecting to get from this setup?
macster
Don\'t help me
Help the bear
  #48 (permalink)
Old 06 Jan 2004, 09:21 pm
quote:Originally posted by Jason_L
an AFR of 10 means 10:1 air:fuel, compare that to 14.7:1 air:fuel.. looking at those a/f ratios, i'd say there's room for more boost..
J
You're right, you beat me to it.
macster
Don\'t help me
Help the bear
  #49 (permalink)
Old 06 Jan 2004, 10:03 pm
What concerns me is that the dyno operators thought 10 was lean? maybe they were looking at the 14's in the 2000-2500 band, where the boost is on strong and the AF is still lean..
- Stage 1
  #50 (permalink)
Old 06 Jan 2004, 10:24 pm
The 14's were what got their attention, especially with the first run entitled baseline lean. They were happy when it started to richen up.
macster
Don\'t help me
Help the bear
vB code is On
Evolution Performance Dyno Day - Saturday, 10/1 Evolution Northeast PT Forum 0 27 Sep 2005 01:12 am
Dyno Results for Hahn Turbo PT!! Ant Turbo Performance 7 09 Feb 2004 08:27 am
dyno danger 026TB4U General Turbo Discussions 0 11 Jan 2004 08:14 pm
Dyno #'s prior to Stage 1 install... rice_killing_GT Stage Turbo Kits 16 18 Aug 2003 08:51 pm
dyno results kruzzinpt Turbo Performance 2 28 Jun 2003 09:52 am
  Credit Cards | Money | Remortgage | Credit Cards | Debt Help
