Stage One Problem
Old 23 Jun 2012, 07:02 am
PT_Panel's Avatar
Send a message via ICQ to PT_Panel
Default Stage One Problem
I have an 06 PT Turbo Lite, Cindy found me a Stage One. I went to the dealership which I trust and ask the tech if he had done the tranny re-learn before and he said yes. I replaced the original with The Stage One and then he hooked up the DRB III to the OBD. He did some things????? with the engine off, then started it up and did a couple of shifts.When he got done the engine light is on, the speedometer doesn't work, the outside temp says 104 and the door locks don't go down after taking off. It threw a code of U1120 Lost Wheel Distance Message. I don't have anti-lock brakes. The question is could he have done something to mess it up or can a computer (Stage One) that is programmed with anti-lock brakes be reprogrammed to not have anti-lock brakes. I know the VIN was done right because from what I have read it wouldn't even run if it wasn't. To me it didn't seem to have any more power and after what I have read everyone is saying there is a big difference. I put the original back in. Any help is appreciated, I am disappointed with the situation to say the least.
06 PT LT Turbo, Back Doors welded in, Glass out, PTzed
Old 23 Jun 2012, 09:03 am
BarbieCar's Avatar
Default Re: Stage One Problem
I just done mine this week, actually had the tech do it at dealership i work at, but somethings might look into,
1. I hear sometimes the wheel size isnt flashed in the pcm data which could effect things like speedo not working..the others? I dont know..
2. You will def feel a diff once u push the gas pedal...mine was put in,,no codes..no issues,
put it in again and have him do it again, a tranny re learn (some say) you can do on ur own.
Old 23 Jun 2012, 01:02 pm
The problem is it could be the PCM or just as easily be the installation process. If I were you I would contact Cindy right away and get her take on it. She's good people and has almost certainly dealt with this situation before. She'll be able to guide you from here.
Yes Barbie, you can very easily do the relearn yourself and it's a lot more fun than standing there watching a tech install it. You just have to find an area to "safely" do it.
Jerry
Old 23 Jun 2012, 02:12 pm
ROCKETMAN8060's Avatar
X2
Dont give up on it my brother! Problably is something easy to fix and you know that finding a Stage 1 for your car is not easy so work with Cindy Im sure everything is going to be fine!!!!!
ROCKETMAN8060
Got my Stage 1 In.. Problem Morkeste Stage Turbo Kits 34 03 Aug 2011 07:21 pm
Stage 1 problem solved ValAir Stage Turbo Kits 7 06 Nov 2005 12:26 pm
stage 1 install problem gooberff Stage Turbo Kits 6 29 Jun 2005 12:22 am
Transmission Problem - Stage I mich_132003 Stage Turbo Kits 22 11 Dec 2003 02:00 pm
Stage 1 in, but still have WOT problem. TurboDanny Stage Turbo Kits 15 24 Oct 2003 04:48 pm
