Dyno numbers
  #21 (permalink)
Old 10 Apr 2004, 03:58 pm
quote:Originally posted by Ant
You can still get a fairly accurate reading through the tailpipe. You would be able to get a good idea of where your AFR is.
I have my on board wideband hooked up in my downpipe before the cat. The dyno stuck it up my pipe
Readings showed 11.2:1 w/ my setup on runs vs. 12:1 dyno wideband.
Ant,
Where did you get your wide band? How much was it? I assume this is in addtion to the stock O2 sensor. I want to put a AF gauge in with one.
thanks
  #22 (permalink)
Old 11 Apr 2004, 05:25 am
Ant Ant is offline
[/quote]Ant,
thanks
[/quote]
I am using the Techedge unit:
http://www.techedge.com.au/vehicle/wbo2/default.htm
I put an extra bung in my downpipe next to the OEM O2 and installed the wideband O2 as well. It works nicely. Gives you exact AFR at all times; cold start, idle, cruising, WOT. Perfect for tuning!
There are quite a few others available now to look at if you are interested.
PT powered PT with:
Fully built HRC Turboed 2.4: Wiseco pistons, T2 rods, Port & Polished head (Bob Special) with oversize Stainless Steel valves, #14 Crane Cams, AF/X UDP, No balance shafts, Custom 3\" downpipe, 3\" hi flow exhaust, Ported GT intake manifold, Bored Throttle Body, 30 lb injectors, Water/Alc. injection
Evolution Performance Dyno Day - Saturday, 10/1 Evolution Northeast PT Forum 0 27 Sep 2005 01:12 am
04 HOGT Dyno and track numbers hoopdiewagon Turbo Performance 27 10 May 2004 02:16 pm
dyno done a few questioons 026TB4U Turbo Performance 9 19 Dec 2003 09:12 pm
Dyno #'s prior to Stage 1 install... rice_killing_GT Stage Turbo Kits 16 18 Aug 2003 08:51 pm
intake - must reset computer? got dyno numbers? secretspy Tech & Performance Forum 4 16 Jul 2003 06:22 pm
