injectors
Like Tree2Likes
Old 17 Dec 2013, 12:27 am
WolfmanG's Avatar
Default injectors
i'm definitely gonna get a stage 1 for Alexa(07 Turbo-lite) but what kinda injectors do i need to get?
-Danny Wolfman G
Old 17 Dec 2013, 01:31 am
needmoretoys's Avatar
Default Re: injectors
I think you may alread have them. Not sure about the lite. But look and see if yours are 527's Look up the specs on your motor. See what color your injectors are. If your going to run bigger injectors you are going to need something(like a Diablo Sport) to run them correctly. I am running stage 2 injectors in mine and had to have my DSP rescaled to run them the right way. Without that I belive I would be dumping to much fuel.
Busa_Powered likes this.
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 17 Dec 2013, 04:59 am
From what I remember, Chrysler put the lager injectors in the Turbo Lite cars in 2004 so that's why the Stage one from 04 up only needed the computer upgrade where as Stage 1 for the PTGT in 2003 also needed to add the lager injectors.
2003 PT GT come with 527cc injectors.
2004+ PT GT's and Lite's come with 577cc injectors which are required for Stage 1.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 17 Dec 2013, 05:55 am
Yes, all the folks above are correct. The lite has the correct injectors.
Rocketman did the autoshift conversion on his lite I believe.
Old 20 Dec 2013, 12:11 am
WolfmanG's Avatar
thanx guys, that info has really helped.
-Danny Wolfman G
Old 01 Sep 2016, 07:54 am
they have some nice Bosch injectors, for sale on ebay, i called the guy, seemed legit but he did say you needed tuning or they wont run right,
Bosch-60lb-630cc-fuel-injectors-Dodge-Neon-SRT4-Caliber-PT-Cruiser-2-4-turbo
bosch 52lb 550cc fuel injectors Dodge Neon SRT4 Caliber PT Cruiser 2.4 turbo
Tbh idk if those are better or not, but hope it helps,
Old 01 Sep 2016, 08:22 am
You're answering a post from Dec. 2013 and no, WolfmanG hasn't been around here for a long, long time.
Jerry
Old 01 Sep 2016, 08:44 am
Fk5 Fk5 is offline
Jerry
He was here this year. I'm not sure if he posts under a different name, but he posted once. I thought it odd because I had not seen him around except maybe on the other board.
As for injectors be careful comparing ratings. Some of the companies rate them at different pressures etc, so a 600 from one place may be a 577. I would like an interchange chart for the 577 injectors. I don't come across many '04 and up turbos in the yard and SRT4s are nonexistent
2003 GT 5 speed
162,000 miles
Old 01 Sep 2016, 09:43 am
He was here June 8 16. But only briefly.
Old 01 Sep 2016, 11:49 am
Need injectors! LRSRTGT Classifieds: Want To Buy 0 22 May 2012 12:33 am
Stage 1 ECM with injectors FS Soulman Stage Turbo Kits 3 17 Mar 2012 11:17 pm
fuel injectors dunnboy Tech & Performance Forum 8 28 Feb 2012 01:28 pm
stage one injectors mattsptgt Tech & Performance Forum 7 07 Aug 2011 08:57 pm
03 injectors vs 04 injectors 4SPEED General Turbo Discussions 1 04 Jul 2008 11:16 am
