stage 1 coming
  • 1 Post By NitroPT
Old 13 Jun 2014, 11:24 am
Default stage 1 coming
Larger injectors...........check
Ngk iridiums..........check
Stage 1 module.........Monday
Dealer appointment........Thursday
Large smile..........check
2008 Sunset Boulevard
Old 13 Jun 2014, 11:37 am
Default Re: stage 1 coming
Following your threads,mods and upgrades...
if you find you get a miss under hard acceleration dump the NGK and get Champion Copper tops.
Ttomes likes this.
Old 09 Aug 2014, 08:36 am
All is running fast and great. Couple problems I've experienced though. The o2 sensor is supposedly bad but I've replaced it twice and it still gives me the light. And the ac has been a problem. I've replaced compressor, evaperator, high pressure line, fan, all relays and the only way I get cold air is to jump from the ac relay to ground. Problem with that is it runs 100% of the time. Ac man says relay is not getting ground signal from computer.
Old 09 Aug 2014, 04:17 pm
LionPT's Avatar
What brand did you install..??
I had same problems with Bosch, replaced it with an NTK & light/code went away.
Fan not coming on BeeJay General PT Cruiser Discussions 3 12 Nov 2012 06:37 pm
Oil coming from somewhere. IamN00bz General PT Cruiser Discussions 6 04 Jun 2012 04:32 pm
Grinding/rotating noise coming from left side of car when coming to a stop...help? quietcharm23 Wheels, Tires, Suspension 3 10 Apr 2011 08:43 pm
Stage II Kit is still coming tthrift Stage Turbo Kits 68 13 Dec 2004 09:32 am
what date is stage 2 coming out?? bobs turbo pt Stage Turbo Kits 17 27 Jan 2004 11:40 pm
