Syked ECU vs Mopar Stage 1
Like Tree22Likes
  #71 (permalink)
Old 10 Dec 2014, 10:07 am
Handy_Cruiser's Avatar
Default Re: Syked ECU vs Mopar Stage 1
Yep. The forth plug is for the tranny control.
myckee likes this.
  #72 (permalink)
Old 10 Dec 2014, 10:26 am
Originally Posted by myckee View Post
No the NA and Turbo ecu's are identical...unless you are talking Stage 2 or 3 ecu's with 'toys'. All manuals have 3 plugs and all autos have 4 plugs. The 'toys' ecus for manual cars have 4 plugs but the last plug is populated with a special plug instead of the trans.
But yes, to reprogram the physical ecu, he needs to have it there to reprogram it.
Didn't know that. When I swapped the turbo light to the n/a for testing I threw turbo codes not auto trans codes. So I figured the other plug was for turbo stuff. Tho only auto n/a I have are 02 back. So no comparison there. I will Have to look into that first chance I get.
Handy_Cruiser and myckee like this.
  #73 (permalink)
Old 10 Dec 2014, 11:02 am
This is really a cool thread. Lot's a good information. It would really be cool to know if Kevin could make a Skyked PCM that just makes the turbo lite compatible with one of the Diable Sport gizmos. Then someone with a turbo lite could have the flexibility to use one or more of the DS tunes Kevin and others are already offering.
myckee likes this.
  #74 (permalink)
Old 09 Oct 2016, 09:46 pm
hes a real nice guy, i got him on the hone a few months ago,
  #75 (permalink)
Old 09 Oct 2016, 10:35 pm
Carnut's Avatar
Any chance he could provide programming to turn off the abs function and dash light?
George H. McDowell
Wichita, Kansas
mailto:carnut@carnut.com
http://www.carnut.com/
FB https://www.facebook.com/george.c.mcdowell
My 2005 PT Cruiser GT Convertible Project
  #76 (permalink)
Old 09 Oct 2016, 11:08 pm
Yes.
The PCM Syked made for my Vert doesn't have ABS. But it needs to be noted that Mopar made both ABS and non-ABS versions of the original Stage 1 PCM for 2006 and 2007 automatic GT's. The part numbers are P5153649 and P5153846. So FWD Performance may also provide the same thing for those year models.
But I don't know if Syked is able to turn off ABS in the 2003 thru 2005 programming. But if anyone can do that, I suspect Syked can. However, I'm not sure it's necessary if the PT (such as a 2004/2005 turbo lite) didn't have ABS to begin with. Myckee may be able to verify that.
  #77 (permalink)
Old 10 Oct 2016, 09:53 am
There is a "disable" available but I sincerely doubt that anyone that has a business will use it even if a release of liability is signed.
  #78 (permalink)
Old 10 Oct 2016, 12:06 pm
First Thank you for the PM and question. I thought I would just answer it here instead of directly to you.
The access of the firmware (topic PCM PT Cruiser) will only disable the complete AIR Bag System not a single component. To eliminate or disconnect a single part like the steering wheel AIR bag you would need to disconnect the part and replace it with a electronic part to equal the electrical specification resistance of the part being bypassed. I DO NOT OR ADVOCATE THIS PROCEDURE ANYMORE.
This has often been a procedure outlined on many DIY threads on various forums regarding replacing aftermarket steering wheels or seats. There are descriptions what was used that claimed work and may work for others doing similar projects.
However as was pointed out to me recently by a representative from *very well respected Perfroamcne line of safety belts and equipment, he stated no one has ever actually tested these "tricks" in a crash simulation to verify that the rest of the safety system will work as engineered. Made me go hmmmmmm!?
Because of this* information I will no longer in future responses show my past projects as how to's regarding OEM safety equipment modifying. Mainly because I can not verify that my safety system will continue to work properly after any changes other then replacement of OEM parts.
  #79 (permalink)
Old 14 Oct 2016, 11:13 pm
_PTGT03's Avatar
can't you just remove the ABS fuse or relay ?
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Any one running the Syked Stg2 flash on their GT? SPLNeon Turbo Performance 3 12 Feb 2015 09:58 am
FS: Stage 1 PCM, composite intake manifold, mopar bov ,mopar wires Nachtsturm Classifieds: For Sale/Trade 9 08 Dec 2011 01:05 pm
Are there any step by step instructions for mopar stage 2 wastegate and or dual stage dmkolb Turbo Performance 7 04 Aug 2010 03:44 pm
FS: '03 GT w/Stage 1 and MOPAR BOV jramosGT Classifieds: For Sale/Trade 3 27 May 2004 08:42 pm
Mopar Stage One kit Mike Radowski General Turbo Discussions 12 09 Jun 2003 08:21 pm
