PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
california emmisions testing?
Old 04 May 2004, 03:41 am
Turbo Tommy Turbo Tommy is offline
Default california emmisions testing?
I have an 03, with auto stick, and would like to do the stage 1 kit, but am concerned about emmisions testing, how do I know it will pass every two years, and one try yet? Let me know. Also if anyone has done this to there autostick, does it change the shifts feel, exhaust sound and all the other stuff chrysler says it will? Thanks
Old 04 May 2004, 12:22 pm
Cal Cruzer Cal Cruzer is offline
You might want to repost with a subject line that includes "...with Stage 1". Lots have been done as you describe.
Old 14 May 2004, 05:14 pm
Kirby Kirby is offline
There could be a fly in this glass of water.
New OBD II testing might need to have ALL of the sensors working, I know that one of the reasons that Stage I will probably not ever be C.A.R.B approved is that it turns off some of the sensors to achieve it's magic. It's a shame too because everyone that has installed the Stage I kit has had passing smog numbers.
If DEQ finds you have modified your vehicle they "could" fine you, most probably they will make you remove the Stage I PCM so you can pass their test.[8)]
Old 16 May 2004, 10:14 am
macster macster is offline
Send a message via AIM to macster
Kirby
"If" is the key. All of our mods need to be stealth like in their implentation. At the most if there are no visual signs, then its just a "sensor failure," problem. If that happens replacing the PCM should take only 15 min at best. But I'm in agreement with you on this, I guess we can "look" forward to the challenge.
m~
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
vB code is On
*UPDATED* California Speedway January 22, 2005 PTGT_Boy Western PT Forum 0 23 Dec 2004 04:26 am
California Speedway September 18th PTGT_Boy Western PT Forum 2 17 Sep 2004 05:10 pm
California Speedway August 21st PTGT_Boy Western PT Forum 3 20 Aug 2004 05:56 pm
California Speedway July 31st PTGT_Boy Western PT Forum 0 29 Jul 2004 09:24 pm
Emmisions inspection w/Stage 1 Gear_Head Turbo Performance 6 05 Oct 2003 04:08 am
  Loans | MPAA | Flights | Online Loans | Loans
