Installed Stage 1
  #11 (permalink)
Old 04 Jun 2004, 06:55 pm
The "ATTENTION" sticker tells ya that this PCM is meant to be used in the vehicle with the following last 6 digits in it's serial number. Then they write your #'s in there.
George
03 GT PT, Inferno Red w/factory flames, AutoStick, Stage 1, Mopar BOV, BTG duals, Airaid, 5 HP fuzzy dice
  #12 (permalink)
Old 05 Jun 2004, 03:40 pm
I am trying to sell wife on stage 2 as an ecconomy measure!!
  #13 (permalink)
Old 06 Jun 2004, 02:21 am
quote:Originally posted by JSWILL70
GG, just curious if you frequently checked your gas mileage before the stage 1? If so, let us know what it is after the stage 1. Thanks
I've only driven my GT about 400 miles since the S1 installation but my gas mileage has definitely improved. It's too early to be specific (possibly 10 to 15%) because I'm still afflicted with "chronic lead foot"!
  #14 (permalink)
Old 03 Jul 2004, 02:26 am
Just a quick question, after installing stage 1, can I switch back to stock easily if I need to to pass California Smog?
thanks
  #15 (permalink)
Old 03 Jul 2004, 05:13 am
nozzano22, since the 2004's have the large injectors, yes you could put the stock PCM back in and go for the smog test. If you had a 2003 where the injectors were smaller in the stock version you would probably be out of luck since changing back to the stock PCM with the larger injectors would make your car run pig-rich.
  #16 (permalink)
Old 03 Jul 2004, 01:16 pm
If the Stage 1 kit for 2004 comes with PCM only it must be possible to download and flash the firware to the stock PCM block without changing it? Or is there more to it than just firmware?
2004 Electric Blue GT 5-Speed
  #17 (permalink)
Old 03 Jul 2004, 02:04 pm
GG
I take pictures of every up-grade I do, and will add yours to my photo file. Thanks, Darrell
  #18 (permalink)
Old 04 Jul 2004, 12:46 am
I like the way you think. However I don't want to go first....[:0].....[B)]
http://www.ptcruiserclub.org/galleries/tow12453/gallery1.htm <-Click here for pics
04 Pat Blue Stage 1 Turbo, 5 speed, K&N drop in & airbox mods & AMX Turbo Pipe, Mopar BOV, TurboXS MBC, Eibach Pro spring kit, K&N oil filter, BTG Axle Back, chrome taillight rings, chrome rear bumper insert, chrome hood ports, Shorty Antenna, Blane hood struts, Kenwood X579 head unit, Home built Subwoofer, Home built grounding kit.
Member Tualatin Valley Cruiser Club
http://www.tvccpt.com
  #19 (permalink)
Old 05 Jul 2004, 12:35 am
I heard one thing is this post I did not like "The only odd thing I notice is that the engine speed increases by 200 to 300 RPM between shifts even with my foot off the accelerator pedal. With my foot off the gas, the RPM increases just by pushing in the clutch. "
I already notice a lag inbetween shifts without S1, now that I hear this I'm uneasy about the upgrade right now. Gary
  #20 (permalink)
Old 05 Jul 2004, 01:37 am
Since I got my '03 GT new the rpm's have stayed up there between shifts both with and without stage 1. I don't and you shouldn't worry about it.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Stage 1 and WGA installed - WOT miss RobGT Stage Turbo Kits 6 21 Jun 2004 03:39 pm
Stage I Installed; Week 1 Update mvandale Stage Turbo Kits 3 07 Oct 2003 11:45 pm
Received & Installed Stage I mvandale Stage Turbo Kits 13 01 Oct 2003 04:33 am
Stage 1 Installed Question Kirby Stage Turbo Kits 6 19 Aug 2003 03:51 pm
Dual Stage Boost Controller Installed!! RobGT Turbo Performance 13 21 May 2003 12:35 am
