PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   Stage Turbo Kits (http://www.ptcruiserlinks.com/forum/stage-turbo-kits/)
-   -   Help (http://www.ptcruiserlinks.com/forum/stage-turbo-kits/61185-help.html)
chromer don 25 Sep 2016 01:45 pm
Help
The red clip that you pull back to release the wiring harness from the PCM is missing and the plug won't stay plugged how do you fix this problem. I thought I saw a fix in the forum and did a search but did not find it.
ptcruisersteve 25 Sep 2016 02:18 pm
Re: Help
Is the black tab also broken for the PCM connector?
chromer don 25 Sep 2016 02:23 pm
Re: Help
Sorry I got it wrong it is the black tab. the red is still attached to the electrical connector. The black tab that locks in the electrical connector to PCM.
ptcruisersteve 25 Sep 2016 02:35 pm
Re: Help
I would suggest temporarily using a few real long high strength zip-ties and use it to keep the plug in place. The proper way is to replace the harness. Maybe other members have some ideas?
CREWZIN 25 Sep 2016 02:37 pm
Re: Help
Once you push the connection together (without the black tab) can you hold it tight and push the red locking tab to one side? That "might" hold the connection together without the black tab.
If not, maybe a cable tie, if you can find a place to wrap it around the connection.
ptcruisersteve 25 Sep 2016 03:27 pm
Re: Help
Make sure the PCM plug is secure. You don't want to be driving on the hwy and have the engine cut out on you.
chromer don 25 Sep 2016 04:15 pm
Re: Help
Duck Tape works wonders. It was the third connector from the left, mines an auto. So it sets between the second and fourth connector. Started the tape over the second connector, over the third connector then ended it at the far side of the fourth connector in one piece. looks like it will hold
GtPt05 25 Sep 2016 08:43 pm
Re: Help
Ya know, I had the same issue. I went to the dodge dealer, because I figured since it's such a common part on these cars, and the genius design is that it can be replaced because the parts are removable (instead of the usual plastic tab that is part of the plug) so I figured the dealer techs are breaking these things all the time, so you can probably buy a little kit in a bag with the black and the red parts, right? The dealer probably has a bin full of these because they are constantly breaking them, right? Wrong. The guy behind the counter looked at me like I was nuts. He then asked the service manager, who looked out his office window at me like I was nuts. He then asked a tech, who spent a lot of time on a computer to come back with a part number for a $100 harness. Are you kidding me??? Nope. They were serious. I asked what happens when they break one while servicing a car. Response was, charge the customer for the $100 harness AND the install, or... zip tie it. I asked if they used genuine Mopar zip ties. They weren't nearly as amused by that as I was.
GtPt05 25 Sep 2016 08:47 pm
Re: Help
By the way... My fix was to run zip ties all the way around the PCM (going over the top and back around from underneath) one on the left side of the plug, then one on the right side, then one horizontally to hold the two ties from moving. If that doesn't make sense, I can get a picture.
chromer don 25 Sep 2016 09:14 pm
Re: Help
Yes sir get me a picture, would be appreciated. The under hood heat is hard on plastic.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241
