Stage 1 and WGA installed - WOT miss
Old 18 Jun 2004, 01:31 pm
Default Stage 1 and WGA installed - WOT miss
Installed Stage 1 and the Turbochargers.com WGA last night.
SICK!!
I have a miss at WOT though.
What is everyone with Stage 1 have for a plug gap?
Currently im running @ .042
Thanks
Rob
Old 18 Jun 2004, 02:03 pm
Mine remains stock--the plug gap has never been changed. No miss or any other problems whatsoever with 1000 miles on STAGE 1.
Old 18 Jun 2004, 08:42 pm
SICK!!
Thanks
Rob
Have you upgraded plug wires? Everyone says the stocks ones can develop problems.
A lot of people are gapping thier plugs at 40 and even 38. I also saw a post about trimming the ground lead back to half across the electrode so the spark develops on the side exposing it to the fuel better.
Also saw an article that the turbochargers.com WGA needs to bypass solenoid #2 for some reason. You might check thier FAQ
Loyd
http://www.ptcruiserclub.org/galleries/tow12453/gallery1.htm <-Click here for pics
04 Pat Blue Stage 1 Turbo, 5 speed, K&N drop in & airbox mods & AMX Turbo Pipe, Mopar BOV, TurboXS MBC, Eibach Pro spring kit, K&N oil filter, BTG Axle Back, chrome taillight rings, chrome rear bumper insert, chrome hood ports, Shorty Antenna, Blane hood struts, Kenwood X579 head unit, Home built Subwoofer, Home built grounding kit.
Member Tualatin Valley Cruiser Club
http://www.tvccpt.com
Old 21 Jun 2004, 12:24 pm
Gapped to .050 and it helped a little.
Then I gapped to .040 and problem solved!
BTW im running stock coil, Magnecore 8.5mm and champion plugs one step colder.
Running DSBC from the back of the turbo out to the WGA.
Only issue is the map sensor keeps shooting out of the stock UCP under high boost.
Old 21 Jun 2004, 12:32 pm
Your Map sensor isn't mounted in the UCP. So I don't know what's shooting out, but that's not it.
\"If I had a diesel rig, with a big ol\' blade, courtesy would reign, arguments abate, cuz everyone would know, I\'d SQUASH \'EM LIKE A GRAAAAAPE!\" -- Heywood Banks, \"If I Had a Bulldozer\"
Old 21 Jun 2004, 12:45 pm
Oops...what is that then??
The sensor right before the TB.
Old 21 Jun 2004, 03:39 pm
Send a message via AIM to macster
That's an Air Temp sensor, I forgot what you call it, but it's about $9.00 if I remember correctly. I have a spare and I will update this when I get home.
m~
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
