PT Cruiser Forum Car Videos
Custom Wheels
1/4 mile times
  #11 (permalink)
Old 09 Jul 2004, 08:44 pm
PTGT_Boy PTGT_Boy is offline
Time to get that mopar short shifter installed .
  #12 (permalink)
Old 10 Jul 2004, 09:02 am
hyracer hyracer is offline
Kloydxyz,
I ran at Woodburn (track elevation 100' above sea level). I generally do not run at Madras since its only a 1/8th mile track.
To readabout the spring trick go to www.exhaustdepot.com
Then on the left hand side click on the SRT4/GT link...once there scroll down the page until you see modifications or maybe its performance modifications. Clicking on that takes you to the spring mod. I use a carb return spring, one end attached to the waste-gate arm and the other end attached to the back of the engine block.
I only use the spring mod at the race track since the computer will eventually "learn" the spring is there and will eventually start pulling power back to original levels. I can take the spring on and off in about two minutes.
In a couple of weeks AGP and tthrift (I'll be buying from tthrift since he supports our site) will be selling a billet adjustable WG that will let us start making the same power as the SRT4's. This will eleiminate the need for the spring trick. Add a manual or electronic boost-controller and a map-clamp (not for the weak-hearted or those relying on thier warranty) and you'll be seeing Stage 2 levels and above.
Deen
  #13 (permalink)
Old 11 Jul 2004, 12:08 pm
pt pete pt pete is offline
The first time i went to the track, (moroso) in florida. I ran 15.1 and 15.3 with horrible r/t times.. I have an 03 autostik gt, the only mod i had at that time was the silencers removed and the normal weight reducing items taken out of vehicle.. I am waiting to install stage 1 before i go back.. getting into the mid 14's should be no problem..
vB code is On
1/4 MILE TIMES WITH STAGE 1 MARKS-GT Stage Turbo Kits 28 17 Sep 2005 05:46 pm
1/4 MILE TIMES JSWILL70 General Turbo Discussions 27 29 Sep 2004 02:26 am
turbo lite ΒΌ mile times turbotouring Turbo Performance 13 11 Sep 2004 12:18 pm
Stage 2 1/4 mile times estimates macster Stage Turbo Kits 12 14 Mar 2004 05:52 pm
dodge stealth 1/4 mile times 026TB4U General Turbo Discussions 13 24 Dec 2003 06:14 pm
  Credit | Credit Card Consolidation | Loan | Remortgage | Personal Loan
