question about syked stage 2
Like Tree5Likes
Closed Thread
  #11 (permalink)
Old 17 Oct 2017, 12:25 pm
_PTGT03's Avatar
Default Re: question about syked stage 2
all you people above are high jacking this thread for your own personal arguments
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
  #12 (permalink)
Old 17 Oct 2017, 12:33 pm
rob302's Avatar
yea scaling is a misused term... or a term used to do things incorrectly.
to do things incorrectly:
people often scale airflow to make the wideband see the number they want to see. like they scale the airflow back so the car runs at 12.8 afr vs the 11.4 it would normally. the computer sees this as an error an adds fuel trying to correct it... or they "fix it" by disabling adaptives or in some cases even disabling the o2's, depending on the level of cutting corners thay choose. these will get you down the track but may not comfortably get you to work every day
to do things correctly:
you spend hours and hours adjusting the air and fuel to be more accurate. so the wideband shows the 11.4 the computer wants, not the 12.8 that you want. once you do that, you go back and edit the fuel tables so the computer is commanding 12.8 instead of the 11.4 it used to want. this takes a long time and is not a mail order thing unless you are sending in datalogs for them to adjust. then you do it again and they adjust it again. the benefit is a car that runs correctly and this will make the car run better everywhere. better mpg, better performance, better everything. this does produce a "one tune that does it all". but this does not come in a box. this is what i do but i will be tweaking it constantly. partially because it's fun.
the first time i learned that was here: https://eectuning.org/forums/viewtopic.php?t=18470 -but nobody explained it clearly like above so it did't click until i actually dug in and started trying to change stuff
the "one tune does all" was mentioned to me in march 2016, but it took me a few months to actually understand.
Originally Posted by rob342
i have it on mode 1 right now, as per here: http://static.moates.net/quarterhorse/qh_notes.txt
i'll try mode 2, but i want to use the external switch to change tunes. i'd eventually like a performance tune, a MPG tune, and a tune that exaggerates the idle lope for carshows
Originally Posted by 85_GT
Yeah, try opt 2. No reason you need all those tunes. One will do all, except if you want to exaggerate and make it idle bad.
Handy_Cruiser likes this.
  #13 (permalink)
Old 17 Oct 2017, 12:34 pm
rob302's Avatar
you already answered it clearly enough with your response. "call syked and ask"
Closed Thread
Silly newb question on the stage1/DSP/Syked options kudah440 Stage Turbo Kits 28 26 Oct 2017 08:40 pm
Syked ECU vs Mopar Stage 1 CruiserMike Stage Turbo Kits 78 14 Oct 2016 11:13 pm
Anyone know how to contact the Syked Tuning guy _PTGT03 Turbo Performance 13 21 May 2016 05:04 am
Syked Stage 1 and 2 mmmadog Turbo Performance 36 11 Aug 2015 01:58 pm
Myckee's Syked Performance Mopar Stage 1 ECU is here! :) myckee Stage Turbo Kits 7 27 Jan 2015 12:25 am
