03 GT Stage1
Like Tree10Likes
  • 1 Post By Shiloe
  • 1 Post By Handy_Cruiser
  • 1 Post By Shiloe
  • 1 Post By _PTGT03
  • 6 Post By myckee
Old 30 Aug 2019, 08:50 am
Default 03 GT Stage1
Can anyone possibly help me out in a few points.. a few years ago I bought my stage 1 from Cindy at Fwd. It along with bigger injectors installed allís been great till a few weeks ago when the onboard ecu memory fried. So I ordered Sykes tuning but had to get a 04 ecu and sent it to him and now the fan is running full speed as well as the fan relay code is on. I didnt have that problem with the other ecu. I know the fan is variable and controlled by the ecu. Does anyone know if itís possible to install my original 03 ecu stock and still use the larger injectors till it can be figured out with the programming?
Handy_Cruiser likes this.
Old 30 Aug 2019, 11:54 am
Handy_Cruiser's Avatar
Default Re: 03 GT Stage1
Originally Posted by Shiloe View Post
Can anyone possibly help me out in a few points.. a few years ago I bought my stage 1 from Cindy at Fwd. It along with bigger injectors installed all’s been great till a few weeks ago when the onboard ecu memory fried. So I ordered Sykes tuning but had to get a 04 ecu and sent it to him and now the fan is running full speed as well as the fan relay code is on. I didnt have that problem with the other ecu. I know the fan is variable and controlled by the ecu. Does anyone know if it’s possible to install my original 03 ecu stock and still use the larger injectors till it can be figured out with the programming?
You need a good 2003 Stage 1 ECU. And the one to get it from is Myckee right here on this forum. He can take that 2004 ECU and flash it to a 2003 Stage 1. And Myckee will be MUCH faster than Sykes. Sykes stays covered up with a backlog of work and the wait time can be pretty long.
For the short term, you will likely be okay running with the 2003 GT ECU with the blue-banded injectors. The ECU will trim the fuel as much as it can. And at worst, you will be running a little rich like many old carbureted engines always did. As long as the engine runs good and no codes are thrown, I myself would be fine with that setup for the short term even if I didn't have any type of diagnostic tools to determine what's going on.
I recommend you contact Myckee by PM and ask him all your questions. No one on this forum is as knowledgeable about all of this as Myckee. He's very sharp.
myckee likes this.
Old 30 Aug 2019, 12:12 pm
Thank you. I did send an 04 to Sykes and got it flashed already and thatís the problem now it causing the issue my prior one didnít. I did pm McKee just waiting for a response. Thanks again 👍
Old 30 Aug 2019, 06:29 pm
_PTGT03's Avatar
Hey dude. I went through the same process and had the same problem, but just needed a programming update and then the fan at full speed was fixed. Because the 03 uses a proportional variable speed drive control, and the 04's use a on-off, two speed controller. When you send the 04's to Kevin to program you have to make sure he knows that it's for an 03. If you return the computer to Kevin and explain what happened he should be able to set it to the correct fan. Since Sykes tune is even more aggressive than the original stage 1 programming.
Shiloe likes this.
Old 30 Aug 2019, 07:54 pm
Awesome thank you Iím hoping thatís just the case since itís asked when you ordered it and include the vin I would have thought it was known. Heís asking to send pics of the old and new ones but have to wait till Sunday before I can get it out again. Fingers crossed.
Old 31 Aug 2019, 07:38 pm
_PTGT03's Avatar
Not only that but you need the specific part number of the 2004 model computer. It happened to me that the one I had wasn't right and couldn't be programmed correctly either.
Old 31 Aug 2019, 09:06 pm
Great.. he never said that when I ordered mine... ugh well I’m gonna take it out tomorrow and see he wants the picture of it first and I’m gonna put the oem non stage in for now so at least it drives just with larger injectors for now...
Old 31 Aug 2019, 10:49 pm
Hey sorry Shiloe, I was away on a cross country adventure with my wife. I just returned home, 9000 km later on my beloved 03 Dream Cruiser, from out West to see the Rocky Mountains.
Anyway you will be fin using the bigger injectors on the original PCM.
Sykes will take care of it, I am sure. Hopefully he will fix and ship it out again without any delay...
If you wish, you can send it to me and I will fix it, for free, so it will work in your car. I also sent you this in a PM.
Cheers,
Mike
How do I know If Im runing a Stage1 PCM? niel Stage Turbo Kits 17 15 Apr 2011 11:19 pm
03 vs 04 stage1 pcm Fuct Stage Turbo Kits 3 30 Sep 2010 10:24 am
15 psi. with stage1!!!! EDGAR TAMAYO Stage Turbo Kits 4 09 Jan 2005 10:55 pm
2.4HO & stage1 BACKinMOTION Stage Turbo Kits 23 09 Jun 2004 02:50 am
'04's Just PCM 4 Stage1??? knowyourturbo Stage Turbo Kits 1 27 Dec 2003 03:20 pm
