PT Cruiser Forum Car Videos
Custom Wheels
HELP Stage one question
Old 09 Aug 2004, 10:40 pm
scottscars scottscars is offline
Default HELP Stage one question
Old Reader, and guy...Here is my question, Stage one is in box , waiting till Sat. to do install, I have played with my car a little and was wondering should I put the car back to the way I got it or leave the "upgrades" alone. Not that I did much, ex: I am sure I could leave the "Baffles" from the air-box to turbo OUT! But what about the MBC, and the "Black-Line Trick (that I got off this form-THANX) When I installed the MBC- I blocked the brown line( to the turbo) and replace it with the "other" line form MBC ( the other of course is vac.) Please any help would be GREAT!! Thanks for all you HELP!!!
Old 10 Aug 2004, 05:23 pm
ajoeb ajoeb is offline
Scottman, #1 remove neg.batt.cable before starting this project. I removed air box and turbo up tubing. Cover turbo inlet with clean rag. All plugs(4auto,3stick)can be removed. 10mm scoket, short extenion. I used 1/4in drive. INSTALL like you removed. Instructions say to do a brake in with your trans,DO it. "I" would do it with out boost controller pluged in. Your in for one nice ride. You will smile as wide as your grill.
Old 10 Aug 2004, 10:44 pm
Thanks!!!!!!
so i will take out MBC, what about the other line??? Should I replace back to stock? or it will not matter?
Old 11 Aug 2004, 01:23 am
JPMS GT JPMS GT is offline
Scottscars, ajoeb, welcome to both of you. Scott, do a search on Stage I and you can get some good hints as to what to expect. I installed S I last week-en and the biggist problem was getting the connectors off. The red tabs slid bac OK but the connectors were hard to get off. Pull out and down with some force and they come off OK. I had to remove my strut brace but the UCP and AirforceOne staid on. Watch out for the clip that holds the windshield washer tube near the cowel. I got a deep cut on that mother.
If you have an 04 GT you just have the PCM, but it now has four bolts instead of three. And, there are two wire harness attachment points on the PCM brackets.
Good Luck! [8)] [?]
Inferno Red \'04 GT Autostick, Stage I, BTG exhaust, Airforce One intake, V.A.K. Candy Red upper charge pipe, BTG strut bar,Hyperground, chrome side spears and grill accents.
Old 11 Aug 2004, 08:29 am
sakigt sakigt is offline
Send a message via AIM to sakigt
I took my BC off, but I doubt I needed to. I just wanted to see if teh car ran the same without it. I did, but it was a tad slower.
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
vB code is On
Stage 1 question stranger Stage Turbo Kits 1 01 Sep 2006 07:59 pm
Stage 1 Question? cycletron General Turbo Discussions 4 26 Sep 2005 11:50 am
Stage 1 kit question DREAM2 Stage Turbo Kits 5 17 Apr 2004 10:59 am
Stage 2 Question Mean Green Stage Turbo Kits 10 20 Mar 2004 07:54 pm
Stage 1 time question AA PT Stage Turbo Kits 11 02 Dec 2003 06:20 pm
  Online Loans | Money | Credit Card Consolidation | Jorge bucay | Loans
