iridium plugs???
  #11 (permalink)
Old 08 Oct 2009, 01:36 pm
Default Re: iridium plugs???
Originally Posted by sugees69 View Post
are the Nology Cool Wires only for the PT turbo?
Over priced and over rated. Just like the iridium plugs.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
  #12 (permalink)
Old 25 Oct 2009, 12:36 pm
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
PT CRUISER TURBO 10.2MM RACING SPARK PLUG WIRES BLUE:eBay Motors (item 260403263272 end time Oct-28-09 14:28:17 PDT)
10.2MM wireset for 30.00. i have them and have had no issues.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
  #13 (permalink)
Old 26 Oct 2009, 08:28 pm
freetobejbp's Avatar
Well, I did'nt know FRAM oil filters are viewed as bad by some. I still plan on giving the FRAM filter a shot. I use Shell oil and gas. I still need help with find good affordable performance wires. Any suggestions?
It all depends on how often you change your oil and filters. I assume you plan to keep that 10k oil filter on through several oil changes i figure at least 3 are 4?
If you change it every 3k are 5k miles a regular duty oil filter is just fine. If you keep a check on the oil you can tell it is getting dirty and starting to break down. I have had my PT for nearly 4 months now i have only put 2000 miles on it the dealer changed the oil before i got it and the oil looked new it already is starting to look bad im getting it changed soon it might make it to 3k but 5k forget it. I plan to use the Castrol GTX high milage 5W-30. Dealer has to use cheap oil.
  #14 (permalink)
Old 28 Oct 2009, 11:55 am
Originally Posted by Taggert_LOA View Post
Reading this thread, is it possible those would fit an 02 non-turbo?
Pete
  #15 (permalink)
Old 28 Oct 2009, 08:09 pm
Chromenut's Avatar
Tag, you're always a fountain of information and knowledge, thanks for this post. These look like a heck of a deal, and at 10.2mm, if they are properly shielded, they would last a lifetime in a PT. Wonder what impedance they're measuring out at? Have you measured yours? Just curious. And Pete, as to fitment, long as they fit in the spark plug well, and attach properly to coil and plug, they should work fine. I'm not sure if the non-turbo head is different than the turbo, probably is, but I would think that Chrysler would only be using one size plug, and one size plug channel. Tag, your thoughts?
2006 PT GT vert: Getrag 5-speed, wind spoiler, billet shifter, 15" billet antenna, chrome brake handle, LED tail lights, Typhoon intake, AMX upper & lower pipe, chrome curb trim, chrome headlight trim, PT sunvisor badges, chrome hood protector, chrome front & rear bumper addons, Mopar BOV, DSP & custom tune, JL Audio sub-woofer, 17x7 wheels...more...
  #16 (permalink)
Old 28 Oct 2009, 08:20 pm
Chromenut's Avatar
I just pruchased a set, so I will do some serious research on how well they perform against the factory wires versus Crane Firewires versus these. After I've run all three for a given number of days (at least two fill-ups on each set), I'll post my findings along with measurements on length, true width (meaning I don't necessarily trust the adverts that say "it's 8.5mm" or whatever), impedance measurements. I'll wrap the wires in a conductive coil and see how much interference they are given off, if any. Couple of heat tests, etc. Would probably be helpful for the PT community for someone to do this, and since I have three sets of wires now I'll volunteer and post the results.
  #17 (permalink)
Old 29 Oct 2009, 12:16 pm
Long live the 5 year old thread............
I run NGK Iridium in all my non-diesel rigs......... Platinum is so yesterday......
  #18 (permalink)
Old 29 Oct 2009, 02:15 pm
Pete
Wires are interchangeable between turbo and N/A.
  #19 (permalink)
Old 02 Nov 2009, 09:42 am
Thanks!!
Pete
  #20 (permalink)
Old 02 Nov 2009, 05:59 pm
Chromenut's Avatar
DITTO DITTO DITTO!!!
gapping iridium plugs Hill Cruiser General PT Cruiser Discussions 4 18 Oct 2005 10:53 pm
NGK Iridium Plugs...Questions I asked the tech crazie.eddie Tech & Performance Forum 10 28 Oct 2004 09:46 pm
spark plugs ote69 Turbo Performance 24 12 Oct 2004 01:44 pm
Iridium Plugs luvmypt Tech & Performance Forum 9 19 Jul 2004 12:16 pm
Denso Iridium Plugs gsharrock Turbo Performance 2 22 Jun 2003 09:09 am
  Spanish Property | Kamala | Submit articles | Find jobs | Debt Consolidation
