Stage 1 re: MA Emissions Inspection
Old 18 Jan 2005, 05:39 pm
Default Stage 1 re: MA Emissions Inspection
Hi folks. I'm new to the forum, been reading the posts for a while but now have registered. I have a new '05 GT and am interested in the benefits of Stage 1. I searched the archives regarding the issue of
emissions testing in Mass. but came up dry. Is anyone out there from Mass. with Stage 1 and if so, how did you deal with the testing regime? I'd rather not replace and remove boards if I don't have to. Recommendations anyone? By the way, I have a 5 speed if that makes a difference.
Old 18 Jan 2005, 09:45 pm
I can only say that California will check for codes, and that the system readiness codes have been set. These are so that the old trick of disconnecting the battery to clear reoccuring codes won't work. The car must be driven a while under specfic conditions to set them. It means the computer has had time to check the monitored systems. A pass DOESN'T mean the systems have passed, just that the check has been run. I don't have a turbo or stage 1, so I will defer to those who do.
Old 19 Jan 2005, 09:55 am
In Mass you get a 2 year free pass on emissions as I recall for a new car, so you wont have to worry until 2007
I would definalty get stg1, your worst case situation, you might have to spend 10 minutes swapping the PCM, really easy. Go for it and in two years try to see if it passes, if not just swap the stock PCM back in.
I have an 03 GT 5spd. Dynoed it in NE Dyno in Worcester, got 225 WHP, 252 WTQ.
Mike
86 Daytona Turbo Z CS T-Tops 2.2 +20\'s A555 Getrag moly plate, Garrett T2 3\"SV 3\" exh GLHS Stg 2 20 PSI Boost
89 Shadow ES Turbo 2.5 T2 Garret A555 Getrag moly plate 2.5 exh
89 Spirit Turbo
90 Daytona ES Turbo 2.5 NPR Cooler, S60 50 Trim, A568 Getrag 3\" Exh +40\'s 3bar Map
90 Daytona Shelby VNT 2.2 T4 A568 Getrag Needs work
00 Durango 5.9 SLT+
02 WJ Grand Cherokee Laredo 4.7
03 PTGT Black 5 spd, Stg1, Mopar BOV
Stage 1 passed TX emissions test JohnM Stage Turbo Kits 6 11 Jul 2005 04:55 pm
Emissions Test With Stage One 2step Stage Turbo Kits 12 04 Jan 2005 01:40 am
State Inspection with Stage 1 in Texas JohnM Stage Turbo Kits 9 04 Jun 2004 11:15 am
Stage 2 info from SRT-4 site dtbrks Stage Turbo Kits 24 26 Nov 2003 05:24 pm
Stage 1 passes CA emissions rice_killing_GT Stage Turbo Kits 21 07 Sep 2003 08:32 pm
  2008 Air Jordan Release Dates | Submit articles | Find jobs | Prefessional Book Reviews | Virgin credit card
