stage1 vs boost controler
Old 19 Jan 2005, 09:53 pm
Default stage1 vs boost controler
could somebody please explain the benifits of going with a stage1 vs pumping up the boost with a boost controler. Or is it the other way around?
Old 19 Jan 2005, 11:28 pm
Send a message via AIM to hoopdiewagon
there are better tuned timing/fuel maps with the S1.
<font color=\"purple\">214whp/246wtq</font id=\"purple\">
Old 19 Jan 2005, 11:31 pm
EDIT: sorry, didnt realize that I didnt answer your question[B)]
just going with S1 will not only up your power, but do it safely with the correct fuel. Just blindly cranking up a boost controller is like throwing matches at a gasoline can...one day it will blow. Before turning up boost, you need to see a/f ratios and at least know what levels you are currently at. Turbos and fuel systems have limits and going past them can lead to some pretty bad stuff.
Send a message via AIM to Mr.Blonde
if you dont have stage 1, and use a boost controller, you will have to deal with the engine going in Safe mode. ( from what i understand)
Now with stage 1
Just a GT... Thats tearin\' arse on the driveway.
http://www.cardomain.com/id/themanfrmokinawa
14.626 @ 94.74
stage 0 , intake and exhaust only.
Old 20 Jan 2005, 03:28 am
It's better to use Stage 1 and a boost controller. Stage 1 has the benefit allowing you to crank to higher boost levels, the Stock ECM will throw a fit if you try to crank anything higher than 15psi.
Of course, visit the dyno to make sure your not running lean.
Old 20 Jan 2005, 03:42 pm
What they said...
Also with S/1 you could plug & play without having to add on gauges to monitor everything. A boost gauge is an absolute minimum for a boost controler.
Final manual boost controller installation Ian-PT-GT Turbo Performance 85 05 Mar 2010 03:04 am
Boost Controler UPP_COS Turbo Performance 0 06 Apr 2006 02:10 am
Stage-1 and a boost controler dfunkdj Turbo Performance 11 25 Feb 2004 06:47 pm
Stage 1 and boost controler? Airbillster Stage Turbo Kits 7 17 Dec 2003 11:42 pm
installed boost controler deez92 Turbo Performance 39 24 Apr 2003 09:12 am
