PT Cruiser Forum Car Videos
Custom Wheels
18lbs lean or not lean
Old 25 Jan 2005, 09:19 pm
steve smith steve smith is offline
Default 18lbs lean or not lean
i buy a mbc and i know i cant pass 18lbs with my original bov so i want to know at18lbs im safe or lean[:I][8)]
Old 26 Jan 2005, 01:59 am
hoopdiewagon hoopdiewagon is offline
Send a message via AIM to hoopdiewagon
nobody can really tell you this. You need to get the a/f checked on either a dyno or with a wideband sensor to know for sure.
<font color=\"purple\">214whp/246wtq</font id=\"purple\">
Old 26 Jan 2005, 06:47 am
hyracer hyracer is offline
According to the SRT4 forums those with Stage 1 boosting to a maximum of 18 PSI are safe as long as you are dropping to 15 PSI (or below) near redline. Boosting past 18 PSI will only net you less HP since the computer pulls the timing way back.
Deen
Old 27 Jan 2005, 10:48 pm
PTGT_Boy PTGT_Boy is offline
You should still visit the dyno with a/f readings.
vB code is On
  Mortgage Calculator | Credit Cards | Online Loans | Free Advertising | Loan
