PT Cruiser Forum Car Videos
Custom Wheels
Cooling Fan Mod
Old 21 May 2005, 11:18 pm
AZ_IceMan AZ_IceMan is offline
Send a message via AIM to AZ_IceMan
Default Cooling Fan Mod
Well I don't really have the convenience of sending in my ecm to get reprogrammed from flight systems. I know that on a lot of cars you can put an inline resistor on the cooling fan circuit to turn them on whenever you want. My stage one has the glitch where sometimes it won't kick the fans on and I just want to be able to click the fans on and not have to turn off and restart the car. Any ideas[:I]
Old 22 May 2005, 01:19 am
Mean Green Mean Green is offline
Why can't you put stage 0 back in and send in your stage 1 for a reprogram? Your GT will run fine with stage 0.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 22 May 2005, 04:13 pm
Can't cause I'd have to mess with my WGA. I have a Stage 2 in there and i'll get the partial throttle boost code and my car will run like crap. [:0]
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
Old 25 May 2005, 04:07 am
gray gray is offline
Go to srtforums to read up on how to .
But i read its the blue and pink wire going into the computer behind the air box bundle of wires there tap into the blue with pink line on it . Run a wire from it to a switch then to a ground when you ground that wire the fans come on. It will throw a check engine light unless you put a 68 ohm resitor inline with the switch . the fans run at medium with 68 ohm resitor . They run on high without it and the check engine light will stay on throws a code so the computer makes it go to high&gt; is what i read.
vB code is On
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
A/C .. and Engine cooling fan mystery delbassman Tech & Performance Forum 9 02 Apr 2007 01:14 am
Cheap Cooling Trick macster Turbo Performance 12 03 May 2003 12:13 pm
PT fever cooling off? CRUZIN NW General PT Cruiser Discussions 38 05 Apr 2002 09:50 pm
  Advertising | Home Loan | Free Credit Reports | Credit Card Consolidation | Equity Release
