Towing
Old 19 Jul 2005, 10:40 pm
Default Towing
I am not sure if this is the section I need to ask this question. I have a '03 Turbo with an automatic. What is the best way to tow? All wheels up or on a dolley or tow-bar? Thanks, Mike
Old 19 Jul 2005, 11:31 pm
Take it from me Mike, both ways will get you there. All 4 wheels up moving to Florida, and the picture shows the other way.
Old 20 Jul 2005, 12:04 am
Mike, do you just want to tow it a short distance or are you going to do a lot of towing behind a motorhome?
Crewzin has addresses the "short" tow. If you are going to tow for long distances, the answer is, it depends.
Towing four down is by far the most convenient (and what I do). It is more expensive due to the cost of the REMCO transmission lube pump and the tow bar brackets you will have to have installed (I use Roadmaster EZ brackets).
Using a tow dolly is the least expensive option (with the automatic) and avoids the need to make "modify" your PT. It is a bigger pain to hook up, you have to have a place to store the dolly (some RV parks don't have enough space at the site for a dolly) and you have to remember to stop after about 50 miles to check the tightness of the wheel straps.
Using a trailer (preferably enclosed) protects the PT the best but the trailer is heavy (the trailer and PT will exceed the 5,000 lb towing capacity of most gasoline power motorhomes and a few older diesel pushers), still harder to find a location for, takes even more time to load and unload than the dolly and is the most expensive of the options.
No free lunch.
Since you have the automatic, it will really depend on whether the added convenience when of towing four down makes up for the added expense and whether you can live with having the tow bar brackets showing. I will add that it does make transmission fluid changes more expensive since they have to remove the drivers side tow bar and reinstall it each time they drop the transmission pan.
Edit:
A few photos:
Towing 2006 behind RV gruszka General PT Cruiser Discussions 5 15 Oct 2005 08:43 pm
Towing with the Cruiser jtdev General PT Cruiser Discussions 8 04 Aug 2005 03:00 pm
towing behind a RV suzieq General Turbo Discussions 6 27 Jun 2004 08:13 am
Towing question(s) westgate Tech & Performance Forum 4 23 Mar 2004 10:26 am
Disable Odometer for towing PT 2coolPT Tech & Performance Forum 14 07 Feb 2004 04:12 pm
