Alright, I was looking on ebay to try to find a cold air intake. Why are there so many different ones? Some are like $3.99 & some are $299. Some say short air intake & others do not specify. My thinking is only K&N is the best. Right? Are there any other mods I need to do when I install? Tomorrow I will go to the library & get the Chilton automotive book on the Cruiser. Maybe that will help.
Mikey ![]() |
Put a K&N drop in filter in your stock airbox. You'll get the same benefits as an open CAI but you won't be sucking in hot engine air. It is also a lot cheaper. Spend the money you save on other mods.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
The K&N FIPK is the pricest - if you look carefully at it, the intake tube gets gradually larger as it nears the Throttle body, and has gentle curves. It also has a plate to block some hot air from the engine.
Short rams are a simple piece of bent tube and a filter at the end. Much debate about this topic - I feel cold air is better, but once you're moving, underhood air temp isn't the issue, flow rate is. I believe (have no proof) that the K&N flows better than the stock ribbed hose. Whether it's worth the price is another story - shop around - I picked mine up from a forum member for about 1/2 list price. One thing nearly everyone agrees on - the stock intake can be improved on - minimally, take the small, white plastic tube (silencer) out of the intake and put a K&N replacement filter in.
\'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler, E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5\", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in \'02 Silver Touring Edition w/87,000 miles |
Thanks |
I've already installed a K&N replacement filter. I noticed a small increase in horsepower on the road & even a little more on the highway. I can actually pass people! If the air intake system is going to be basically the same performance as the K&N replacement, I will probably just keep it. I do not know what white tube you are talking about. My Cruiser is still in the shop so I can't look at it. I will check it out as soon as I get it back. Does removing this tube increase the horses a little more?
I miss my Cruiser. ![]() Mikey
05 Bruised Cruiser [B)] |
I installed an Injen air inake, which is basically a K&N FIPK minus the shield and the pipe is metal not plastic. Injen makes a heat shield which you can purchase separately. K&N makes Injen's filters, so you'd have the same gains for about half the cost. I too had a K&N replacement filter, but switched to the Injen and had a noticeable difference.
| F/S 3" AEM Cold Air Intake Bypass Valve | AZ_IceMan | Classifieds: For Sale/Trade | 0 | 08 Aug 2005 06:06 am |
| 3" cold air or 2 1/2 " hot air intake ?????? | amx1397 | General Turbo Discussions | 12 | 25 Jan 2004 12:35 pm |
| Cold Air Intake | Mean Green | Turbo Performance | 8 | 10 Oct 2003 03:57 am |
| Real cold air intake | Airbillster | Tech & Performance Forum | 5 | 02 Sep 2003 02:26 am |
| A TRUE cold air intake | Airbillster | Turbo Performance | 7 | 14 Aug 2003 01:19 pm |
