PT Cruiser Forum Car Videos
Custom Wheels
Premium Fuel
  #21 (permalink)
Old 10 Aug 2005, 07:18 pm
steve smith steve smith is offline
if you dont run under 8 lbs of boost they damage notting of coarse you have to instal a boost gauge because turbo lite engine run at 8lbs max and they use regular gaz
black 2004 limited edition with turbo lite stage 1 mopar bov and boost gauge. prototype power kit. k&n air filter s2 wga ebc greddy profec type 2 http://turbocruiser.monchar.com/
  #22 (permalink)
Old 10 Aug 2005, 08:17 pm
coolvanillagt coolvanillagt is offline
quote:Originally posted by AZ_IceMan
quote:Originally posted by coolvanillagt
Thanks Ice man and red GT...fellow "zonies". I'll keep using my QT top tier premium. Do either of you attend the monthly PT cruise in Glendale?
No, i might if i knew more info. Care to shine some light on the topic?
Check out Arizona High country PT club site(there's a link here I believe). It's once a month at Fast Eddies...34th and Glendale area.
motortrendforummoderator
  #23 (permalink)
Old 11 Aug 2005, 03:21 pm
fritz_t_coyote fritz_t_coyote is offline
quote:Originally posted by wengerda
Do I think that the dealer will use cheap gasoline, hell YES!!.
OK, no problem....
Just call the SalesCritter, and the SalesManager, and say "DO NOT PUT GAS IN THE CAR".
The splash the factory put in should be enough to get you to a gas station.
www.visualizecommonsense.com
  #24 (permalink)
Old 11 Aug 2005, 04:34 pm
bigdogdad bigdogdad is offline
That's basically what I would do. Not alot of money involved but you will have peace of mind. The past few cars I've bought I also tell them not to prep the car, I'll just check it out before I sign the papers to make sure nothing appears to be wrong. I got a car one time and they must of had some that had no clue what to do and preped the car which ended up having tons of swirl marks. Wasn't happy
  #25 (permalink)
Old 16 Aug 2005, 02:17 pm
King_Rob King_Rob is offline
The town I live in ONLY has normal grade gasoline. I have to drive about half an hour to get prmium fuel. This means that on NUMEROUS occasions I have used no-premium fuel, but have never had a problem. I always try to fill up with premium, but sometimes I am trapped with no options other than to put normal fuel in my tank.... and after a year and a half I havent had any problems from these few indiscretions with the lower class gas.
04 PT GT, Xenon Crusher Body Kit, Tinted Windows, Clear Gen 4 Tail lights, Clear TYC Backup Lights, Chrome Package, Single Scoop \"Good Hood\", Eibach Lowering Springs, Mopar BOV Conversion, Air MAx CAI, Black Crystal Headlights, Pioneer Stereo with Kicker L7 SW.
  #26 (permalink)
Old 16 Aug 2005, 02:30 pm
SteelBlueGT SteelBlueGT is offline
Where generally are you that has only a one tank gas station. Never thought that was a possiblility!!
  #27 (permalink)
Old 16 Aug 2005, 02:31 pm
Espresso Espresso is offline
I just posted something about fuel grades in the gas price thread. For those of you who INSIST that you must use premium( all you Hi-po GT people)..read this.
http://www.usatoday.com/money/autos/...emiumgas_x.htm
You cars will run FINE on regular, you just wont haver as much performance. I thought people knew this. If you have it modified, then you more than likely have to use premium. But if all you have is a boost controller, then turn it down to stock boost levels & you will be fine.
I used to tow ALOT of stuff with my old V8 Tundra & used ONLY regular fuel. There was NEVER any noticable difference between the two grades of fuel. I could tow my VR4, parts, a loaded bed & 3 people & still be able to pass people on the interstate with no trouble at all. Alot of time the power actually suffered when I used premium.
**Ofcourse** if you choose to run regular, then you may run into preigintion problems. The best thing to do is gauge it yourself. Put in a 1/2 tank or so. If it works fine then just keep adding reg. If the preigintion gets to bad for you. Then add some premium. It's kinda a guessing game as each engine is different. I know quite a fe waround here with Hi-po's that run reg with no troubles.
  #28 (permalink)
Old 16 Aug 2005, 03:04 pm
Instead of editing .
here is what I was looking for if there were any doubters.
http://www.ftc.gov/bcp/conline/pubs/autos/octane.htm
  #29 (permalink)
Old 16 Aug 2005, 07:05 pm
MichaelDay MichaelDay is offline
I concur that using higher grades of gasoline than recommended by the manufacturer is typically an exercise in futility. I also agree that the computer will attempt to back the performance down to match the lower grade of gasoline.
If you are actual hear pinging you can be pretty sure that the computer isn't being able to compensate for the grade of gasoline you are running. Remember that Chrysler does recommend Premium fuel for the HO Turbo. I am fairly certain that the PCM program in the turbo-lite and the HO turbo are significantly more different than just limiting the boost to 8 psi.
There are some who are not able to get 91 octane gasoline and the manual indicates that this is OK but you will experience less performance. Per the manual: "High quality unleaded gasoline having a minimum octane rating of 87 may safely be used for your vehicle. Use of these lower octane gasolines, however, may result in reduced acceleration performance."
As always you should avoid heavy spark knock. The manual (page 181 in the '03 GT manual) states: "Continued heavy spark knock at high speeds can cause damage and immediate service is required. Engine damage resulting from operating with heavy spark knock may not be covered by the new vehicle warranty."
In a nutshell, the answer to the original question is if they put a tank of regular in, problems should NOT arise in the future. If you are following the Chrysler recommended break in directions you will probably not notice the difference during the first 200 miles.
  #30 (permalink)
Old 17 Aug 2005, 09:02 am
wengerda wengerda is offline
quote:Originally posted by MichaelDay
Well I was told that they delaer used 89 octane. I did not have a chance to tell them that I was going to fill up the tank myself. Well the vehicle performed perfectly with 89 octane. My tank is semi empty. I am waiting for the gas light to come on and fill with premium gasoline. In my area (Northern VA) premium gas is an extra 20 cents, meaning an extra $2.00. Oh well, as I always say "Do not buy a car if you can't afford the gas" Thanks.
vB code is On
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
Checking interest in new fuel mod for turbo PT MarksPtGt Turbo Performance 11 02 Jul 2006 08:18 pm
All 2002 Cruisers Recalled??? zzzhuh General PT Cruiser Discussions 18 24 Mar 2004 05:12 pm
  Mortgage | Loans | Advertising | Loan | Electricity
