I have an 01 cruiser purchased brand new in 00. 109,xxx miles. It was driving fine - no funny noices or anything, I make a right hand turn onto my street and the engine just died. It has never done this before. The battery is fine but the engine doesn't turn over - doesn't even have a turning sound. Kind of like if you disconnect the battery and try to turn it over... but the radio is on. Any advise? A fuse, alternator, etc
It would take longer to type out instructions than to do the basic checks. Like JSB said, check for voltage at the starter and 'start signal' there too. That will get you to the wiring branch that is causing the problem. Keep checking that circuit until the fault is found.
2004 Dark Plum Base with windows tinted, cabin filter, silencers removed, fog lights, 18\'s, all Red taillights, Blaine\'s struts, modesty cover, color-matched center dash, 06 rear bumper |
First of all, take a deep breath and relax. It's probably something simple (cheap to fix).
It could still be the battery or battery cable conection. The radio does not pull much power. Headlight strength is a better place for a fast, first check. Next would be the other wiring connections in the starting and ignition systems. Sorry that I can't be more help. Good luck with it. |
First start with checking the oil. (If you ran it out of oil it will stop and never turn over) (Also check the radiator fluid. If your head gasket leaked, you cylender might be full of antifreeze which does not compress and thus you cannot turn engine over)
Then check the starter (bypass the ignition system and it should turn over) If starter turns, then check fuses, ignition switch (things like that) Is it a 5-sp? It also could be the clutch safety switch. Just some things to check on.
GT is the only way to go |
| 2004 Chrysler PT Dream Cruiser Series 3 | skylight | PT Cruiser News and Rumors | 10 | 18 Jun 2009 08:57 am |
| 2006 PT Street Cruiser Route 66 Edition | skylight | PT Cruiser News and Rumors | 35 | 17 Nov 2007 02:39 pm |
| 2007 PT Street Cruiser Announced | skylight | PT Cruiser News and Rumors | 0 | 16 Aug 2006 08:47 am |
| 2006 PT Cruiser Pics and New Specs | skylight | PT Cruiser News and Rumors | 14 | 13 Nov 2005 08:46 pm |
| New 2005 Convertible PT Dream Cruiser | skylight | PT Cruiser News and Rumors | 4 | 11 Jan 2005 06:12 pm |
