PT Cruiser Forum Car Videos
Custom Wheels
disconnecting battery
Old 12 Aug 2005, 07:30 am
gonzomania's Avatar
gonzomania gonzomania is offline
Send a message via AIM to gonzomania
Default disconnecting battery
I just did the champion double platinum plugs and the magnecor wires. Should I disconnect the battery to reset the computer and for how long? Just thinking on this the other day because I would guess it would spark different than original plugs.
Old 12 Aug 2005, 08:36 am
tpscruiser tpscruiser is offline
Gonz,
Disconnect the neg (-) terminal for at least 2 minutes to reset the computer. You may have to reprogram the clock and radio stations.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
Old 12 Aug 2005, 09:53 am
Jimbo Jimbo is offline
I always heard 10 min., but 2 is more than likely enough.
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
Old 13 Aug 2005, 05:26 pm
thegoldpt's Avatar
thegoldpt thegoldpt is offline
Send a message via MSN to thegoldpt
Dumb question,
You wont get shocked by this will you? Just take a crescent wrinch and undo the cable for 2 mins?
2005 Linen Gold 5spd
PT Cruiser Links Moderator
Old 13 Aug 2005, 06:18 pm
xyster xyster is offline
No you won't get shocked by this if you are careful. You might see or hear a spark when you put it back on, but don't worry much about it
2001 Ltd Ed. Inferno Red PT, many mods, many more to come.
Old 14 Aug 2005, 10:05 am
Just make sure it doesn't come in contact with the pos cable
(Steel Blue)
Old 14 Aug 2005, 11:57 am
Gary04GT Gary04GT is offline
While disconnecting the battery for a few minutes is fine it isn't really neccesary as the PCM automatically makes ajustments according to your driving style. I recently changed sparks plugs, lowered the gap in the new plugs to .040, added Magnecor ignition cables and a 2.5-inch Mopar/Borla dual exhaust system without ever disconnecting the battery as I had done previously. I experienced absolutely no issues or concerns. After driving a couple hundread miles my car's performance was the BEST it has ever been in 16K miles.
Just my two cents. [8]
Old 14 Aug 2005, 01:17 pm
Espresso Espresso is offline
Why reset the ECU when changing plugs & wires? What would you do when adding a 50 shot of nitrous oxide?
You only need to disconnect the battery ( both pos & neg) when working on something electrical. I've taken out engines with out even touching the battery. The only reason you need to do it is for safety, not for the ECU to "relearn" A/F ratio's ect..
Old 15 Aug 2005, 09:56 am
AZ_IceMan AZ_IceMan is offline
Send a message via AIM to AZ_IceMan
Yeah well on plugs and wires, should be ok without unplugging the battery. For other things, yes....and not just electrical. On turbo cars, a quick reset will do the car much justice when for example your car is turbocharged and you get some bad gas and the car pulls timing because of the pinging and predetonation, the knock sensor will not simply correct itself anytime soon. You need to reset the pcm because the timing will stay in a retarding state and will kill your hp. Just shedding some light on the subject...thats all, not criticizing your knowledge by any means. [^]
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
vB code is On
PT Crusier battery dies after 5 days of no use. PT OWNER General Turbo Discussions 16 11 Apr 2006 03:43 pm
Battery Corrosion SteelBlueGT General Turbo Discussions 9 19 May 2005 06:47 pm
BATTERY SOURCE NEEDED clevelandmike General PT Cruiser Discussions 3 06 Oct 2004 09:54 am
Disconnecting battery cable TaylorMade Tech & Performance Forum 6 08 Aug 2004 11:24 am
Volume reduced when battery disconnected tom-t-rifik Sound and Security Forum 0 28 Jun 2004 05:25 pm
  Remortgages | Auto Loans | Home Insurance | Web Advertising | St. Louis Pool Contractor
