PT Cruiser Forum Car Videos
Custom Wheels
After market Fog/Driving lights
Old 06 May 2003, 07:49 pm
steve059 steve059 is offline
Default After market Fog/Driving lights
Hello
New to fourm, did a search on this mater, couldn't find anything, hope someone can help. I bought after market driving lights installed Them in the right spot, found the hock up wire there behind the cover, connected it to the new lights, no go, wire I guess is not conected to fuse pannel, I was woundering if anyone can give me a tip on where to hock up the lights, instead of going throught the fire wall,
Thanks
Steve
2003
Old 04 Jun 2003, 11:39 pm
yellowpanel yellowpanel is offline
Hi Steve
Your problem is that there is no switch to turn on. Cruisers with factory installed fog lamps have a different signal-headlamp switch then Cruisers without fog lamps. You will need to find the wire coming from the front of the car that does the foglamps and wire it to a switch or replace the signal-headlamp switch with one that has the foglamp function. I'm not sure if the wiring that you found goes all the way to the steering column but it is likely. Be careful not to poke around the Airbag wiring. Deploying the airbag by mistake would ruin your day.
mike@trickcruiser.com
www.trickcruiser.com
Old 16 Jun 2003, 04:23 am
PTKodiak PTKodiak is offline
Send a message via AIM to PTKodiak
Hi,
We have a 2002 base model that didn't come factory with the fog lamps.
I was able to get a multifunction switch off of ebay (stock turn signal switch with the fog light switch built in), and a set of used fog lights from ebay also....
Anyways....I have all the wiring details....and can walk ya thru it. You can use an aftermarket switch to run them, no need for the stock switch. I can even tell ya how to wire it up so the aftermarket switch will turn on the green dash lite indicating the fogs are on.
Let me know if you need info.....Dalec74@commspeed.net
Dale
vB code is On
Hella fog lights question PoconoPT Tech & Performance Forum 2 05 Apr 2006 10:43 am
PT Cruiser 1959 Cadillac tail lights available Marge Classifieds: For Sale/Trade 2 03 Dec 2005 01:16 pm
LIghts, Lights, Lights King_Rob Classifieds: For Sale/Trade 4 20 May 2005 09:14 pm
Warning: Undercar lights and a lowered PT CREWZIN Exterior Accessories Forum 8 15 Mar 2004 06:07 pm
APC Next Generation Tail Lights Jeff V Exterior Accessories Forum 10 21 Mar 2003 01:17 am
  Debt Consolidation | Credit Cards | Loans | Credit Counseling | Mobile Phones
