Spark Plug Wires
Old 14 Oct 2005, 01:57 am
thegoldpt's Avatar
Send a message via MSN to thegoldpt Send a message via Yahoo to thegoldpt
Default Spark Plug Wires
I have been hearing alot about people redoing their spark plug wires to performance models, what should i expect to pay? What are good brands to consider? What performance and fuel economy can i expect? And is it good for a newbie to be playing around with this stuff, or shoud i have an expert do it?
Old 14 Oct 2005, 09:32 am
MY OPINION:
There is NO performance benefit from wires on the PT. After around 20,000 miles on up, better wires will give back some performance you've lost from the crap stock wires going bad.
I think the best value are the Crane wires from RaceAndStreet for under $50.
Old 14 Oct 2005, 02:22 pm
If you are not experiencing misfires, (check the PCM codes with the 'turn the key on (not START) and off 3 times quickly and read the codes on the odometer- there are lists of error codes available on this forum)
Factory plugs and wires are good for about 25-30 thousand miles.
At which time replace them both (actually the factory plugs probably have more reliable life left than the wires, but it is such a Pain in the Tailpipe to get to the wires, you might as well do the plugs while you are in there.)
Detailed instructions, and various brand and gap recommendations, are on these forums too.
Remember:
Use the bungee-cord trick to hang the upper intake manifold, saves you a bunch of unbolting.
Put some clean rags into the lower intake manifold, as letting bits of dreck fall into them would be a Bad Thing.
Dielectric grease on the spark plug boots will make your life easier someday.
Anti-Seize on the plug threads will save you, or the next guy, a Bunch of money someday.
Welcome Aboard....
Perusal of this forum will be very educational.
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
Old 14 Oct 2005, 02:33 pm
thegoldpt's Avatar
Me nor my parents have any idea on how to do this stuff, and sence it looks as though i may have to take off the intake manifold to do the wires, i don't want to **** it up anymore than the poor thing already is with the noise it is making, plus i think i will get my life out of the stockers, then maybe i will get the new wires.
Old 14 Oct 2005, 11:11 pm
thegoldpt: see my enty in the performance section on the slight miss I cured with new plugs & wires. Total cost less than $60.00!!!
HOOLIGAN
Old 15 Oct 2005, 12:58 am
I've had three PT's and have seen crappy factory wires go bad at around 12k. Others have, too. It's not a for sure they will go bad that soon but I'd replace them just the same.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 17 Oct 2005, 10:12 am
???? What kind of noise? [:I]
Old 01 Nov 2005, 02:27 pm
Send a message via AIM to harrisonmml
worth every nickel, get magnacor wires and champion double platinum plugs, revel enterprises has both if you can't find them locally, less than $80 total, there are plenty of good web sites to show you how to do it, with step by step pictures etc, it is time consuming but not difficult. try ptdoiyourself on th web, mike the mechanic has lots of time saving tips.[8D]
Old 13 Nov 2005, 02:04 am
I really like my combo of MOPAR high performance wires and NGK Iridium plugs on my GT! So far about 12,000 miles on them and they perform like the day I installed them!!
Old 13 Nov 2005, 12:08 pm
Crane, Magnacor, and Taylor Cable Wires, are all high quality spark plug wires...you really can't prove that one brand is better than the other. The difference between the respective manufacturer's is in pricing. Shop some of the automotive supply houses on the Internet and your're bound to find a "deal" to your liking. Spark Plugs are also a matter of personal preference. I've stayed with Champion but run one heat range colder than stock. [:I]
02 Patriot Blue Ltd. Ed., BTG Performance Springs, H&R Struts & Shocks, Keystone dual scoop hood, Whipplecharger kit, PT Fueler, BTG Dual Cat/back Exhaust with trim flanges, JBA header, Airaid Intake System, English Burl dash kit and steering wheel, 18\" Moda wheels and Conti tires, Muth signal heated mirror kit, Kustom Kruzr license bracket and auto shift kit with ivory knob, Xenon flush mount rear spoiler, Color Matching Paint on bumpers, pillar posts, side mirrors and WeatherTech Windflectors.
Best Spark Plug Wires for 03 Turbo? zzzhuh General Turbo Discussions 10 13 Oct 2005 04:49 pm
spark plug wires dzinman Tech & Performance Forum 1 28 Jul 2005 01:25 pm
no-name spark plug wires Probedude Tech & Performance Forum 9 11 Jun 2005 12:13 am
Replacing Spark Plug Wires LT Almond GT Turbo Performance 4 08 Jan 2004 10:49 am
PERFORMANCE SPARK PLUG WIRES RODRUN Turbo Performance 1 03 Jul 2003 11:20 pm
