{K&N DROP IN }OR AIRADE air intakke system??
Old 14 Oct 2005, 08:47 pm
mjb457's Avatar
Default {K&N DROP IN }OR AIRADE air intakke system??
[8)]Ok overall which is better for gas MPG ???? & torque?? Who has run both & which is better.... I know price is about $30.00 VS $150.00 but forget price if given for free which is best system between these two.. thanks for input,, MJB
Old 14 Oct 2005, 08:57 pm
thegoldpt's Avatar
Send a message via MSN to thegoldpt Send a message via Yahoo to thegoldpt
I would get the full intake, but i can afford it so i am stuck with the drop in............[xx(]
Old 16 Oct 2005, 02:47 pm
I used a drop in and did a Mr.Tee airbox mod and loved it.[8)]
Old 16 Oct 2005, 02:51 pm
thegoldpt's Avatar
If you are going with the air box model, remove that stupid intake silence at the top of the airbox. It is a little white tube like thing at that top of the air box, it slides right out. You will get a little better gas milage.
Old 17 Oct 2005, 10:00 am
MY OPINION:
Cold air & flow are what you want. The stock does suck air from the wheel-well, which is cooler, but is restrictive.
The best intake (opinion) is the K&N FIPK. Next is BTG, then AirAid, then the rest.
The K&N replaces more of the intake tract, has a bit of a heat shield, but is also expensive.
I feel that once you are moving, the temperature difference between underhood and wheelwell air is MUCH smaller than when you're stopped, and then flow becomes important.
Keep your eyes on the Classifieds area - many folks trading in a PT take off their mods - I got a great deal on an FIPK from a Forum member.
Old 17 Oct 2005, 08:24 pm
From experience, the AiRaid 2001 - 2005 does not fit the 2006's. DC has modified the air box and made it smaller. Does it help?? [:I] I cannot tell so far [:I]. AiRaid hasn't manufactured one for the '06 at this time as they didn't know about the change until I told them.[xx(]
Inilex Satellite Tracking System for PT Cruiser Tee It High General PT Cruiser Discussions 4 18 Jan 2005 11:47 pm
Looking for feedback on 3 inch turbo back system.. scottmech Turbo Performance 22 29 Feb 2004 11:30 pm
