spark plugs for 2006 PT
Old 01 Nov 2005, 02:31 pm
Send a message via AIM to harrisonmml
Default spark plugs for 2006 PT
Does any one know if the same plugs for an '05 will be okay for an '06? Just picked up a new '06, and find the performance lacking compared to my '03 with Magnacor wires and Double Platinum wires, I know the wires are the same, but what about the plugs? Thanks
Old 01 Nov 2005, 02:57 pm
Same. Only change to engine was plastic intake on turbos (actually started as a running change in '05).
Old 01 Nov 2005, 05:37 pm
Champion 7440 or RE14PLPS sure improved the performance in my '06
Old 02 Nov 2005, 10:18 am
Which is the right calibration for the sparks .40 or .50
Old 02 Nov 2005, 11:49 am
There was an earlier Chrysler service bulletin to gap the spark plugs at .040 instead of .050. Drivability is improved as well as overall performance. No effect on gas mileage, although some owners reported better gas mileage numbers.
Aftermarket spark plug wire sets, like Magnecor, Crane, or Mopar Performance, also solved many mis-fire problems. The OEM spark plug wires sets have been often replaced by owners and service departments because of the wires failing or have worn out prematurely, so the consensus is to just buy aftermarket spark plug wire sets for maximum longevity and reliability.
[8)]
Old 02 Nov 2005, 11:55 pm
OK gap is .40 but wich would be better Champions Double ,Iridiums or NGK iridiums and I guess the cranes 8.5 are perfect
Old 03 Nov 2005, 02:26 am
If you use Champions use the Copper Plus and [u]NOT the Platinums</u> as they are too hot a plug for the turbo.
Old 03 Nov 2005, 09:33 am
Is not turbo 2006
spark plugs ote69 Turbo Performance 28 11 Jul 2010 09:59 am
E3 Spark Plugs CREWZIN Tech & Performance Forum 6 11 Dec 2004 01:03 pm
Spark plugs: newbie question Edwin Astacio Tech & Performance Forum 12 01 Nov 2004 12:21 pm
ZEX Spark Plugs Jerry Tech & Performance Forum 9 27 May 2004 07:32 pm
Ignition Questions....need help. spark plugs ptcruzin42 Tech & Performance Forum 5 15 Mar 2004 08:39 pm
