Rough Idle with Heat on
Old 05 Dec 2005, 10:44 am
Send a message via AIM to Carchrism5
Default Rough Idle with Heat on
I live in CT and it has been very cold, like 25 degrees this morning, and i have noticed in the morning when i go out and start the car up and turn the Heat/ Defroster on it doesn't idle smoothly, like it will go from 800RPMs to 1,100RPMs, it sounds like someone is pressing the gas repeatedly, i can hear it when i go inside. Has anyone had this problem or know how to fix it?
Thanks
Old 05 Dec 2005, 11:01 am
I believe that's normal. When you put defrost on, it automatically turns on the A/C. The A/C, plus cold temp, tell computer to keep engine idle high. Leave the fan on 0 until it warms up a bit.
Old 05 Dec 2005, 11:14 am
QSD hit the nail on the head! Also when you turn on the Rear Window Defroster/Heated Mirrors and Heated Seats (if equipped), you load up the charging system and that can cause some roughness at idle.
John & Terry
"His" - 2002 Inferno Red Touring Edition
"Hers" - 2003 Electric Blue Limited Edition
Del Val PT Cruisers
New PT but rough idle?? Ed Tech & Performance Forum 6 03 Oct 2009 08:03 am
Rough Idle on 2003 Pt- Not plugs and wires Jungle Jim Tech & Performance Forum 6 27 Mar 2007 09:22 am
rough idle when stopped pvtsnowball Tech & Performance Forum 4 18 Jan 2006 04:12 pm
Rough Idle BlueBlurCruiser General PT Cruiser Discussions 15 07 May 2004 09:50 am
Rough idle PTPaul Tech & Performance Forum 1 17 Oct 2001 05:34 pm
