PT Cruiser Forum Car Videos
Custom Wheels
Sudden loss of power(need tune up?)
  #11 (permalink)
Old 04 Jan 2006, 02:25 pm
Ctown Ctown is offline
update on my sick PT
1)alternator OK
2)Battery OK
3)air filter cleaned
4)going to change plugs and wire in a few day and see if anything changes
5)The Shifter bushing is broken on one end and chysler only sell the whole piece which is $140 O THANK U chysler for seling us such a quality item........PLUS making us replace the whole peice......it's crazy it's like if your tire worned out u need to change the entire wheel along with the tire.....
  #12 (permalink)
Old 04 Jan 2006, 07:57 pm
bobs turbo pt bobs turbo pt is offline
any better with the 3 items you changed or cleaned ??
  #13 (permalink)
Old 09 Jan 2006, 03:14 pm
fritz_t_coyote fritz_t_coyote is offline
If the problem is just the cheap-crud spongy rubber factory bushing, you can upgrade to Booger Bushings for about 22$.
http://www.boogerracing.com/boogerbushings.html
Besides fixing the problem for less $, you also get crisper shifts.
www.visualizecommonsense.com
  #14 (permalink)
Old 09 Jan 2006, 06:04 pm
Here's the full SAD update.
1)Did a tune up plug and wires (parts and labor) $100
Problem - Bad gasket, oil is leaking inside the spk plus....yes miss firing......one spark plug can't be replace too tight......so it was oiled and have to wait until the oil get to to the threats to loosen it up.....if they forcifully gun it it may break and my buddy say I WILL need a new cylinder head.
The Good - after replacing 3 spk plugs and wires last friday the car got full power back no weak feeling and no jerking...no more misfiring. thats only 3 plug I'll wait and see what happen when I get my car back tomorrow
2)The shifter cable bushing is broken and the WHOLE line need to be replace because dealer don't sell that bushing along(another reason not to buy chysler - parts = $200 labor $240 = $440
They say it cost so much for the labor is because the engine need to be tilled to have it remove and install I beleieve them with that tight PT engine compartment
Problem - the shifter can be loose any moment and I don't wanna stuck in 5 going 90mph...most be fix
What I could have don't myself - it's possible to replace the bushing yourself with any $10 home made rubber piece but better to be safe
3)Timing belt and water pump replacement .....labor $260 parts(from ebay $60 BUT they say the belt tensioner is worned and would not last another 6 month the cost for that part(KIT) $200!
I'll have the full result by tomorrow noon but just this mid life crisis is costing me well over $900 luckily I have a decent job these days and not in school anymore or else.
MORE PROBLEM - interior plastic panels popping off my it self one speaker is bad and the gap on my dash board is getting bigger and bigger and I need a rear bumper cover which cost around $400 each! and I need a paint job on the rear of the car.....I figure this mid life fix for this whole car would cost me atleast $1500 when it's all over....in some way I should have lease this car......the down payment these days is 3000$down and 100/month for 27 month..........but than this is my car and if i don't fix it it'll hurt my wallet even more later
  #15 (permalink)
Old 09 Jan 2006, 06:13 pm
O MAN!!!!!!!!!
Why didn't I post earlier! dealer don't sell that part and it's like $200 for the cable and labors $240
$26 dollar vs. $440 is ALOT! O man I feel like I got hit real bad Well I'm sure it will break again around 140,000 miles
  #16 (permalink)
Old 10 Jan 2006, 10:01 am
Be sure some anti-seize gets on the threads of those spark plugs...
  #17 (permalink)
Old 13 Jan 2006, 09:08 am
KingKole02's Avatar
KingKole02 KingKole02 is offline
I was just breezing through here and noticed I have the same problem with my cruiser at just under 50 thou. I did my wires and plugs myself at 20,000, stock plugs were crap. Did double plats and magnecor 8.5mm wires, pt ran great after.
My Pt felt really sluggish and had bad electrical problems, like the lights diming out to start and when the A/C fan came one, OMG it was like the PT wanted to shut down. I got a new battery and installed myself considering they wanted me to seat around and wait for 2 hours to install. It ran better after by far.
Now I have the sputtering and feeling of stalling out sometimes too. I guess I will have to invest in some Crane wires this time around. Plat plugs should be OK I guess and the stock spark box will stay. Other then that it may need a check on the fuel filter, water pump, PCV valve, timing belt, and the cat. But only one of those I can check myself.
Well I hope to keep reading this and see if you could figure out the problems you are having because they sound alot like mine, with the exception of the manual tranny.
KingKole02
SW Florida PT Cruisers Secretary/Treasurer/Webmaster
www.swfloridaptcruisers.com
Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics
For cruiser pics go to:
http://ptcw.truckmoxie.com/mygallery.ten?id=3464
http://smg.photobucket.com/albums/v8...0in%20my%20PT/
For my personal page, visit
http://www.kingkole02.com
http://random-input.blogspot.com
http://www.ptcruiserweekly.com
www.WeKnowDna.com DNA Guided Nutrition
www.TheDnaDiet.info Fox 4 Study Report
  #18 (permalink)
Old 14 Jan 2006, 04:15 pm
make sure to have some one with exp check to see if your valve cover gasket is going bad and no oil is leaking into your spk plugs! also replace the manifold gasket when you do the tune up
  #19 (permalink)
Old 14 Jan 2006, 05:29 pm
OK I got my car back and heres the update
the car feel like it has MORE power. I can keep in high gear even in very slow speed without downshifting at all
the shifter now feels more stiff
everything is great and I have no problem at all now one happy pt owner after $900
  #20 (permalink)
Old 14 Jan 2006, 09:47 pm
CREWZIN CREWZIN is offline
If your still happy after spending $900 to fix your problem, I have some tail lights, Undercar computer controlled LED lights, OEM back-up lights, cargo net and a rear shelf to sell ya.
2000 PT. 95K miles, Original Owner
vB code is On
  Debt Consolidation | Debt Consolidation | Credit Cards | Find Local Jobs | Download movies
