where is the fuel filter anyway?
Old 04 Jan 2006, 02:33 am
Default where is the fuel filter anyway?
I can't seem to find this bastard.
all the fuel filter on my other cars are in the open but I can't find it in the PT
Old 04 Jan 2006, 08:54 am
Inside the gas tank....
Old 04 Jan 2006, 10:45 am
Absolutely correct...and for anyone reading this..that's why you should never run your fuel tank down really low. The fuel filter and fuel pump are at the bottom of the tank. The pump is cooled and lubricated by the fuel/gas itself. Running the tank really low could cause the pump to burn out. Info from our resident PT GURU (Thanks Mike).
Old 04 Jan 2006, 02:18 pm
right confirm by my neighbor........pretty dumb idea though just to show u the guy putting this car together never had a used car for more than 50k miles in his or her life
Old 03 Jun 2009, 10:23 am
Default Re: where is the fuel filter anyway?
Ok about the fuel filter on an 06 PT Cruiser, if it's inside the gas tank do I have to take it to a mechanic shop to get it replaced? Also I'm being told to replace it every 30K, is that right? Sorry I'm not familiar w/these things and unfortunately don't have anyone to help me with it. Any help is appreciated. Thanks. Or you could email me @ Blonde32girl@aol.com. Thanks.
Old 03 Jun 2009, 11:06 am
SRG SRG is offline
Originally Posted by Darlene816 View Post
Ok about the fuel filter on an 06 PT Cruiser, if it's inside the gas tank do I have to take it to a mechanic shop to get it replaced? Also I'm being told to replace it every 30K, is that right? .....
30K??!!! No, not that soon. I don't even remember hearing of a recommended service interval. Anybody??
Replacing the fuel filter involves raising the car, dropping the tank, pulling out the pump assembly. then, putting it all back together again. Probably you don't need a master mechanic to do it, but since you're dealing with fuel, you would sure want someone who knew what hes doing.
Carey is right, don't run low on gas all the time, ithe gas helps keep the pump cool.
srg
Old 22 Jul 2009, 06:47 pm
There are many sites online which sell just the fuel filter (without the pump). Does this mean that you can replace the filter without replacing the pump. Has anyone on this list actually replaced a fuel filter without replacing the pump?
My '01 Cruiser with 73k miles is hesitating when I step on the gas hard and I think the filter needs to be replaced, but I'd rather not replace the pump at ~$300.
Thanks...
Old 22 Jul 2009, 07:24 pm
My Cruiser only has 12K on her, however, I have a 97 Dodge Ram 1500 that has 132K miles on her and I have never replaced the fuel pump or the filter and all is well. First time I took it in for a tune up, mechanic said that the filter was not a serviceable part unless the pump is replaced.
Hope this helps........Rick
Old 22 Jul 2009, 08:00 pm
I had 87,000 miles on my '02, have 77,000+ miles on my '05, and know of many other PT owners with well over 100,000 miles - never touched fuel pump or filter.
Old 22 Jul 2009, 09:25 pm
Fuel is much cleaner these days than it was, say, 30 years ago. Most pumps now have filters on the filler hoses. Also fues systems on our vehicles are now closed and not vented to the outside. So your not going to get the dirt in your fuel system like you would have in years past. That's my take on fuel systems now days.
2001 LE, Shale Green, Aftermarket Wheels, Shorty Antenna, AirRaid Cold Air Intake, Whelen Talons (amber/white) in front windshield, Whelen Talons (amber) in rear side windows, Tomar RECT25's (amber) and Whelen Slimlighter(amber) in back window. Kenwood TK-880H 45 Watt Mobile Radio, Antenex 3db antenna w/ NMO mount.
http://smg.photobucket.com/albums/v7...0PT%20Cruiser/
Fuel Filter? 1lowufo Tech & Performance Forum 7 06 Jun 2004 08:24 am
All 2002 Cruisers Recalled??? zzzhuh General PT Cruiser Discussions 18 24 Mar 2004 05:12 pm
