PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Speedometer swings on rough roads
Old 08 Feb 2006, 04:03 pm
tonganoxie pt tonganoxie pt is offline
Default Speedometer swings on rough roads
My 2001 PT has developed a strange issue. When I drive over a divide in the road (like at a bridge) or a bit of a bump, the speedometer will drop from what ever my speed is (hwy speeeds 60-70) to about 45mph causing the cruise to increase rpm's etc etc... It doesn't matter if it's on cruise or not, same result just not as much of a surge.
I'm at about 85000 miles, have just replaced plugs and wires and this did nothing to resolve the issue.
Idle is smooth, everything seems to be in order otherwise.
Thanks for any input.
Old 08 Feb 2006, 05:58 pm
bobs turbo pt bobs turbo pt is offline
if i read this right you are loosing power ?? is your speed going down to 45 ?? i would check the transmission fluid or something wrong in the transmission [:I]
Old 08 Feb 2006, 06:53 pm
no power loss, or loss of speed, just the speedo goes from 60 to 45.
Old 09 Feb 2006, 10:26 am
quicksilverdon quicksilverdon is online now
Just a hunch, but the speed sensor could be going or wiring to it is flaky.
Not sure where it's located - maybe buy a Chilton's or Haynes manual.
The fact that cruise acts up means it isn't the speedometer but the signal feeding the speedometer (and cruise).
Old 09 Feb 2006, 02:07 pm
Thanks a bunch, I'll check it out and let you know the results.
Old 09 Feb 2006, 08:00 pm
good luck !! [8)]
vB code is On
Tire Size and Speedometer Jetcab Tech & Performance Forum 8 08 Nov 2004 09:58 am
Rough Idle BlueBlurCruiser General PT Cruiser Discussions 15 07 May 2004 09:50 am
Help Please. Speedometer Calibration in New York ckoh General PT Cruiser Discussions 2 09 Jun 2002 01:52 am
  Advertising | PrePaid Credit Cards | Xecuter 3 Mod Chip | Car Insurance | Flights
