| Site Home | Forum Home | Photo Gallery | PT Events | PT Videos | Car Videos |
I am experienced a little shimmy only when acelerate from 0 mph to 5mph and then disapear , this a 2006 non turbo.
The dealer could not fix the problem and decide to schedule with a Chrysler official mechanic [specialist]. Any ideas pls help |
Did dealer admit there is a problem? I little bit of shimmy isn't unusual for front-drive w/a big 4 cyl. The fact that it goes away with speed seems to indicate there's nothing major wrong.
\'05 Limited Turbo Lite, (Silver, of course)4-wheel ABS, Sunroof, Spoiler, E&G Classic grill, K&N FIPK, BTG duals, rear lowered 1.5\", LED washer lights, $20 catch can, Aoogah horn, Weatherflectors, Sunroof Deflector, Fuzzy Dice, rear logo flames, rear pinstripe graphic, Gen3 Taillights, rear sway bar, hood struts, Strut bar. Traded in \'02 Silver Touring Edition w/87,000 miles |
any dented rims ??
Is the 'traction control' kicking in?
I just tell anyone who asks that "PT" stands for "Plymouth's Tombstone" www.visualizecommonsense.com |
I've seen tires cause this very low speed shimmy or squirm. Check all the usual (tire pressure, lug nut torque, suspension for loose components) then rotate the tires to see if it changes.
2004 Dark Plum Base with windows tinted, cabin filter, silencers removed, fog lights, 18\'s, all Red taillights, Blaine\'s struts, modesty cover, color-matched center dash, 06 rear bumper |
"rotate the tires to see if it changes"
good idea !![?] |
The Pt is aligned and balance I will try to rotate the tires but like I said slighltly vibrate when accelarating on initial drive off then
then as the speed increases the wobble/vibration is not apparent anymore This is non turbo 2006 |
