PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Need alittle help...
Old 20 Feb 2006, 04:23 pm
superjes001 superjes001 is offline
Send a message via AIM to superjes001
Default Need alittle help...
Hello everyone. I'm new to this site but I was wondering where the best place to find performance upgrades. What is avaiable for pt cruiser that isn't turbo or supercharger and has the highest hp increase. Thanks
Old 20 Feb 2006, 06:21 pm
gonzomania's Avatar
gonzomania gonzomania is offline
Send a message via AIM to gonzomania
Try the search feature and it will list all kinds of stuff. Good luck
Gonz
Old 20 Feb 2006, 07:33 pm
The search feature? I just want to know the best of the best to buy performance products.
Old 20 Feb 2006, 08:36 pm
CREWZIN CREWZIN is offline
Hi,
Gonz was just trying to point out that doing a search on the forum will bring you all the information you would need, but if you don't care for that way, I'll start off by saying the Non-turbo PT wasn't built for speed. If you want to bump it up a little bit without breaking the bank, a free flow air intake, and less restrictive exhaust. Decent plugs at the correct settings and better plug wires will keep it at optimum performance.
Lowering the center of gravity by the use of lowering springs and an upper strut bar will help with cornering, road holding and straight line performance. As soon as you can, get rid of the stock Good-4-A-Year tires. There's plenty to choose from.
Then you get to the good stuff....plenty of BLING, upgraded wheels, pin-stripes or flames......now your talkin!
Old 20 Feb 2006, 10:39 pm
Alrigth i'm already have way there. I ordered at set of 19" konig sideways rims, eibach sport springs and a strut bar. I was looking for intake whats the differnce between a free flow intake from a noraml APC intake for an example. less restrictive exhaust would that be the system such as bora or magnaflow? Thanks for all your help. I also ordered a carbon fiber hood and i'm searching for an body kit i'm thinking about going with the xenon crusher.
Old 21 Feb 2006, 06:06 pm
paully paully is offline
There is literally a ton of aftermarket parts to mod out your PT, starting from mild to wild. Take a look around the forums and check out the different PT in the galleries to see what look appeals to you, then you can start spending the bucks on the mods.
Purplecruiser/\'01 LE, 19\" Motegi DPK all around, Progress Springs/DropZone Shocks, Carriage Works Billet Grill, Flowmaster Dual Exhaust
Old 21 Feb 2006, 06:44 pm
Black_GT Black_GT is offline
If you want to mod the drivetrain of an NA PT without going to see Hahn, then don't expect a huge gain. The normal routes apply here: free-er flowing intake and exhaust. Synth oil. Plugs and wires. More indepth mods would include: cams, porting and polishing head, switching to a GT intake manifold, motor mounts to get the power to the ground more efficiently, shave the head and dek the block to get a bit more compression, etc... Stay away from the snake oil, like the Tornado, the electric supercharger, AIT chips, etc.... Spend some time searching the forums (not just this one) and see what others have had success with.
This was originally posted by GR8FLPT on another (better) forum:
[quote]quote:
This is what I have done to my ole' 01 LE PT. Just about everything short of opening the motor up & swapping out cams & pistons...
Well I have been getting quite a few emails about my old car. My 2001 LE auto because of the mods I did to it. I felt it would be better to write something up to help out those with N/A PTÂ’s.
1st mod that makes sense is modifying the stock air box. You can buy a after market CAI & bypass all this but I do not believe it is going to be that much more improvement over what I have done to mine. I ended up modifying the stock box because of cost vs. performance. I feel that my stock air box pulls (allows) as much air after the mods as any of the other aftermarket versions out there for a fraction of their cost.
My cost after the mods was around $48, a lot cheaper than the FIPK. ThatÂ’s money in your pocket or for other mods.
The only CAI box I felt that really did the job completely was the Volant CAI. It is an awesome looking & performing CAI. ItÂ’s about the same price as a K&N FIPK. The Airaid is a close second & then the K&N FIPK. The reasoning is I think the heat shield on the K&N FIPK could be better. I believe the K&N FIPK still sucks in some hot under hood air.
Anyway, 1st remove the interior white snorkel tube. If you are willing to work at it, you can cut it down; reglue it back together to get a smooth transition into the inlet hose to the TB.
Remove the white paper filter & replace with a K&N drop-in filter.
Now here's the part that really made the difference as far as the air box was. I removed the snorkel tube that goes to the fender. Then I went to Home Depot & bought an assortment of 3” plastic drainpipe elbows & couplers. I cut a hole in the bottom section of the air box where the stock snorkel was mounted. Then I enlarged the hole to 3". Then on a chop saw (hack saw will work fine) I cut the 45-degree elbow to fit where the old inlet tube would fit.
I then cut the coupler in half. I epoxied one of the half’s to the outside of the section of tube that would fit outside the box & glued the other “ring” to the tube on the inside. This held the elbow perfectly.
I sanded the edges for a smooth transition & made sure that the tube & box did not hit the fender & cause a rattle. I further added a piece of foam to around the hole of the fender opening to the new inlet pipe. This insured that none of the heat of the engine compartment was getting in. Now I had a TRUE COLD AIR INTAKE!
You can insulate the air box with aluminized bubble wrap (insulation). This will help in reducing the air temp also.
2nd mod:
Adding a Header. I canÂ’t tell you how much this helped the low end on my car. I used a Hedmann 4-2-1 header. There is a debate over these & which style or brand to use. Personally, the Hedmann did the job for me. They are a PITA to install & you really should use a lift. It will make it that much easier. Any advice here is some of the heat shield bolts come out from above & some from below. Just check which is which otherwise you will tear them off the shield. The shield is thin aluminum.
3rd Mod:
Swap the exhaust. I went with BTG duals. 2.25” pipe. The N/A pt needs some backpressure. The BTG’s also have removable baffle
2004 PT GT -Stage 1, K&N Drop-In, Airbox Mods, \'05 Composite Manifold, AMX TTAB, NGK V-Powers at .040, Magnecore KV-85\'s, Mopar BOV, BTG Strut Bar, Mopar Rear Sway, Drilled/Slotted rotors, Hawk HPS Brake Pads, a few visual Mods, a coupla Road Runners, and a Partridge in a Pear tree......
Old 21 Feb 2006, 11:26 pm
bobs turbo pt bobs turbo pt is offline
welcome superjes !![^]
Old 25 Feb 2006, 11:26 am
xyster xyster is offline
I'd say a hahn turbocharger... but if you live in Cali with all the emmission laws n having to get it smogged afterwards...
http://www.hahnracecraft.com/
"*Some products listed are legal for sale or use in CA only for racing vehicles which may never be driven on a public highway."
I'm still PO'd that it may pass the smog check itself but isn't.
The best investment so far that I put in performance wise was my K&N FIPK Air Intake. Increased throttle response, beefier sound, more air flow (you can mod out the stock airbox to get this too), etc.
Theres alot of other brands out there equally as great such as Airforce One intake (get it with a heatshield or mod one for it). It sounds pretty good too (somewhat different sound) and as far as everything else, didn't notice any difference really from mine.
Wires and plugs don't really help out an extreme amount, but with the little things (idling stutter, a little quicker go... slightly noticed gain... slightly). Then again they aren't that pricey.
Do a quick "SEARCH" as was mentioned... you'd find alot of what you want to know already discussed in full.
BTW Check the classifieds here. There are many good deals to be had for performance when they are being sold.
G-luck!
2001 Ltd Ed. Inferno Red PT, many mods, many more to come.
Old 25 Feb 2006, 12:20 pm
Jimbo Jimbo is offline
I don't have anything to add, just wanted to wish you luck and
most of all have fun.
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
vB code is On
  Power Rangers | Free File Hosting 1 GB per file | Advertising | Watch How I Met Your Mother Online | Loans
