PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Transmission issue...
Old 20 Feb 2006, 09:54 pm
MDCruiser MDCruiser is offline
Send a message via AIM to MDCruiser
Default Transmission issue...
I have an 03 PT Limited with almost 59K miles on the car. I notice when I'm on the highway driving from 50-70mph I hear this weird whirring noise. (It's easier to hear at 50-60 of course.) When I step on the gas and the trans (auto) is in lockup (where the rpm is below 2500 or so), this whirring noise happens when I step on the gas. I'm assuming it's the transmission.
I took the car to the dealer, and they said a transmission range sensor was bad to the tune of $180. It was replaced, and I also had it flushed at 30 and 60K like the book says. The noise is still there. I'm going to take the car back to the dealer next week probably, but I was wondering if anyone has had the problem I did.
Thanks! [8)]
Old 21 Feb 2006, 04:15 pm
Hooligan Hooligan is offline
My 02's tranny went out at 47K miles, no indication of any problem before that. Tranny maintainance was done at 30K. It was rebuilt (under warranty) with all new parts, but just didn't "feel" right after that.
Got rid of it and bought a 06, and never looked back.
Old 21 Feb 2006, 05:29 pm
rszappa1 rszappa1 is offline
Hooligan...you might be looking back because it is the same old Auto..Tranny.....with all of the problems...
Old 22 Feb 2006, 12:18 am
I'm taking the car back to the dealer on Friday and test driving it with them so we can agree on the noise. They are going to fix the car correctly or else I'm going to call my lawyer again and that will be that.
-Paul
03 Limited, Deep Cranberry with GT wheels
Old 22 Feb 2006, 02:15 am
thegoldpt's Avatar
thegoldpt thegoldpt is offline
Send a message via MSN to thegoldpt
one word...........
Stick
2005 Linen Gold 5spd
PT Cruiser Links Moderator
Old 22 Feb 2006, 06:20 pm
As a sidebar, the dealer told me they wouldn't charge a checkout charge if they found another problem directly realated to the sensor already replaced. I am curious what the trans range sensor does anyway, I've never heard of it before now.
-Paul
Old 22 Feb 2006, 09:55 pm
rszappa1, yes, I know, but it is new with a 5 year Chrysler Extended Warranty.
Old 23 Feb 2006, 12:02 pm
Actually, I've read that there's a pin in the auto that could work loose, and when it does, it eats the tranny real quickly. Supposedly, this pin was redesigned so it won't work loose as readily, I think in '05 trannys on......
Still problems with clutch packs leaking/failing.
Old 03 Mar 2006, 01:28 am
quote:Still problems with clutch packs leaking/failing.
That's what they said last weekend, it was failing some sort of clutch test. They're replacing the entire transmission under the 7/70 warranty, $100 deductible. They have the car right now, should be done Friday or Saturday they said. The new tranny will also be covered for 3 years/36,000 miles.
I'm very disconcerted to have to replace a tranny at 58K miles, but I'm glad of the powertrain warranty and the 3/36 on the replacement. Since I am upside down by about $6k right now (yes, even with 0% financing!), I don't really have a choice.
The PT is a fun car, but it will be my last American car ever. I think I'd rather crawl through broken glass then go through the headaches that I've had, with American cars in general and Chrysler in particular. [xx(]
-Paul
Old 03 Mar 2006, 01:13 pm
bobs turbo pt bobs turbo pt is offline
glad they are getting it fixed for you & i hope you dont have any other troubles ,
vB code is On
Transmission downshift problem Floyd Harris Tech & Performance Forum 5 05 Jul 2006 07:18 am
Manual Transmission Fluid Change matt87951 Tech & Performance Forum 4 06 Jan 2006 07:12 pm
Transmission fliud - B&M Trick Shift or not? snakepitt1 Tech & Performance Forum 8 22 May 2004 06:58 pm
2002 PT Base Transmission tmichalow Tech & Performance Forum 12 21 Mar 2004 02:30 pm
A Few Thoughts On The Mopar Issue Steve03GT Turbo Performance 10 12 Jun 2003 05:36 pm
  Free Myspace Layouts | Credit Cards | RBS credit card | Loans | Loans
