I have a 2005 non-turbo w/manual tran. that has had the same problem since I bought it new but no one(the dealership) can come up with an answer.
When the fan for the heater is turned on or when the fan for the radiator comes on there is a noticable drop in power. you can feel it in the car as well as see it on the tach. They say that no codes come up. and that the rough idle is normal. How can you sell a new car where the rough idle is normal? I have replaced the plugs and wires and I have replaced the air filter w/ a K/N with no change. |
Is the dealer agreeing with you on yor loss of power when either fan comes on? If so, and he's also agreed that your supposed to have a rough idle, ask for a demonstration ride in a similar equiped PT from the lot with a mechanic or the service manager with you. If there's no rough idle, and no loss of power on the demonstrator, ask him why?
![]() ...just CREWZIN along! ® . . . PT Cruiser Links Moderator ![]() 2000 PT. 96K miles, Original Owner Visit My Home Page www.CREWZIN.com |
Have you checked for any codes yourself? Put the key in the ignition, turn key on-off-on-off-on (not start-off-start-off-start!). Any codes will display in the odometer window. if all you see is "done", then there are no codes. Report back to us....
2004 PT GT -Stage 1, K&N Drop-In, Airbox Mods, \'05 Composite Manifold, AMX TTAB, NGK V-Powers at .040, Magnecore KV-85\'s, Mopar BOV, BTG Strut Bar, Mopar Rear Sway, Drilled/Slotted rotors, Hawk HPS Brake Pads, a few visual Mods, a coupla Road Runners, and a Partridge in a Pear tree...... |
when this loss of power occurs at night (on a dark road) I can also see the lights dim for a second. Could be as simple as a bad ground? |
I have an 05 and when I first noticed the problem they said it was normal due to the OE plugs and wires and then replaced them. It seemed like it seemed more powerful but it did not seem to help the intermittent loss of power while either of the fans ingage.
hi justine, sounds like a simliar problem my wifes pt has only sometimes when fan comes on idle will go way down even stall the car !! then you can start right back up, this happens once every blue moon , the dealership said they found a loose wire ( yer right) again it happens every now and then no fix here either keep us posted if you find anything out good luck bob
| How to get power to my mp3 player & other concerns | Doktor X | Sound and Security Forum | 3 | 29 Jul 2005 10:38 pm |
| Where to tap for power for elec. boost gauge? | NorthernPT | General Turbo Discussions | 3 | 18 May 2005 10:32 pm |
| K&N drop in a waste of time? | Blue Streak | Turbo Performance | 8 | 09 Mar 2004 03:41 pm |
| Lack of power, need a lead foot? | hondast1100 | Turbo Performance | 7 | 28 Dec 2003 12:33 pm |
| Power Outlet | Ed Lim | General PT Cruiser Discussions | 1 | 11 Jun 2003 09:40 am |
