switching to gt intake manifold?
  #11 (permalink)
Old 21 Mar 2006, 11:06 am
So in other words, unless you really think you need it, its not worth it. [:I]
Kingkole02
Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics
  #12 (permalink)
Old 21 Mar 2006, 03:55 pm
So, based on the replies, this is how I see the breakdown:
Plastic Turbo Intake on Turbo car = 8-10 HP increase due to better airflow distribution and plastic intake stays cooler.
Metal Turbo Intake on N/A PT = some HP increase, may not be noticable. Hard to install on N/A.
Plastic Turbo Intake on N/A PT = More HP increase, but still may not be noticable, due the the fact that N/A already has a plastic manifold. Air flow distribution amount on N/A is still in debate. Install is still difficult.
If you add the Plastic Turbo Intake on an N/A, please let us know the results and keep us posted. I'd like to know whether this mod is worth the effort.
2002 Inferno Red PT LE (Auto), Blane Hood Struts, 3rd Brake Light sign - SERENITY
AirAid Intake, Chrome Taillight covers - more to follow
  #13 (permalink)
Old 22 Mar 2006, 11:27 am
You got it.
I just want to add a coupla things...
The metal intakes can be picked up cheaply from those turbo guys who've swapped to plastic.
With the metal turbo intake, you don't have to remove anything to replace plugs & wires!
  #14 (permalink)
Old 22 Mar 2006, 01:51 pm
quote:Originally posted by bobs turbo pt
all that work for 8-10 more horsepower ?? is it really worth it?? do you even feel the difference ??
You say that like it's not much of an increase. 8-10 more horse power is better than zero more horse power. Hell, I know guys that would kill to get 8-10 more horse power. In the long run it all adds up. 5 here 10 there, before you know it, you have added allot more horse power.
  #15 (permalink)
Old 22 Mar 2006, 02:09 pm
Send a message via AIM to Goldmember
I swapped my plastic intake out with a powder coated GT intake, There was some minor changes that had to made the Coolant intake has to be moved. The second and more important change the non Turbo intake has 3 vacuum lines the GT intake only uses two. I used a T - on the Vacuum line to the brakes and its worked just fine. As for the HP gains it small, but I did notice the milage got slightly better. The GT intake is louder than the stock intake
Boring Gold PT, oops that was 4 years ago
  #16 (permalink)
Old 22 Mar 2006, 04:23 pm
Goldmember,
Well I guess that means you need to give us an explanation about how hard it is to install then.
I'm going to heat coat my intake someday, then I will notice a difference I hope. Just enough to keep my trying new things I think.
Kingkole02
  #17 (permalink)
Old 14 Jan 2010, 03:12 pm
ROCKETMAN8060's Avatar
Cool Re: switching to gt intake manifold?
This is some info that I found about the plastic intake:
Google Image Result for http://www.ptdoityourself.net/tl/images/library/03gtnewmanifold.jpg
ROCKETMAN8060
  #18 (permalink)
Old 14 Jan 2010, 03:34 pm
chris15's Avatar
Default Re: switching to gt intake manifold?
Also, just a little tidbit, from my readings over on PTCrew, apparently Chrysler remedied a lean condition in cylinder 4 by adjusting the dividers inside of the intake runners..
2001 PT Turbo - In the process of a major overhaul.. :]
2006 Cobalt SS/SC - Stage 2, 3" Exhaust, Meth and soon to come: Zex 75-shot :]
  #19 (permalink)
Old 14 Jan 2010, 08:26 pm
Does anybody knows where I can buy this intake? I want to give it a try!!!
ROCKETMAN8060
  #20 (permalink)
Old 14 Jan 2010, 11:21 pm
ChefTank's Avatar
i'll tell you if you quite bumping three year old threads to give advice LOL j/k they can be had at any dealership, ask for 05+ turbo plastic intake manifold upper and lower w/ bolts and oil dip tube/stick. all part numbers can be found at PTCrew.com - Learn it or Burn it.
Josh
Stock Turbo 300+ ft/lbs wtq
Stage 3 powered PTGT 25psi and lovin it!
Tial Ext Gate FTW!!!
discoloration of intake manifold ptgt2point4 General Turbo Discussions 3 01 Nov 2005 01:41 pm
Torque question for intake manifold on a GT crazie.eddie Tech & Performance Forum 5 29 Oct 2004 04:00 am
DRILLED INTAKE MANIFOLD FOR BOOST GUAGE amx1397 Turbo Performance 6 24 Feb 2004 02:50 am
polished intake manifold(( IT"S HERE)) amx1397 Turbo Performance 25 07 Jan 2004 11:35 pm
Upper/lower intake manifold gasket leak? im4gzs Tech & Performance Forum 14 03 Jan 2004 01:52 am
