While stopped at traffic light and car is idling, the engine will stutter/hesitate a couple of times. No roughness in accelerating. No hesitation cruising. Any ideas?
Â’03 Automatic, 44K. |
Thanks for the suggestion. But wouldnÂ’t weak spark plugs/wires cause the hesitation problem at all speeds. I was wondering if it wasnÂ’t the automatic transmission at idle.
had the problem with wifes 04 pt the dealership said it was a loose wire , fixed it and all has been fine
Hey Ken - did changing the plugs and wires cure the problem?
I have been having the same issue with my '04. I had the dealership change out the plugs and wires as well as had my injectors and throttle control cleaned. It was only a day or two later that the problem returned. Took the car back to them - they drove all day couldn't get the engine to hesitate or stall. So if you did change out plugs and wires and it worked - what plugs and wires did you go with, I don't think the ones they put in are doing the trick. |
hi all got a prob with engine when we pull away the engine labours for a sec like there is dirt in fuel if we keep revs up she ok but when we r dooing slow speed then she will stutter any idea"s
Datalink,
You just asked that question in another thread. Probably the same answer as above with any stumble, hesitation and rough idle....ignition parts.
I used Cranes from RaceAndStreet.Com. Plugs - If you don't have a turbo, you can use platinums for longer life. If you have a turbo, copper or irridium only.
| Emission sensor on, engine hesitation | higear4 | General PT Cruiser Discussions | 6 | 25 Jan 2006 07:09 pm |
| Slight hesitation | DMW | General Turbo Discussions | 3 | 03 May 2005 03:36 am |
| Hesitation | Mean Green | Turbo Performance | 6 | 31 Dec 2004 08:42 pm |
| Idling Question about Stage 1 ??? | retroman715 | Stage Turbo Kits | 8 | 26 Aug 2004 12:04 pm |
| hesitation | JST CRZN | Tech & Performance Forum | 6 | 23 Oct 2001 04:49 pm |
