Noisy Brakes!!!
Old 27 Mar 2006, 02:15 am
Default Noisy Brakes!!!
I'm sure some of you have had this problem...
I have an '04 PT Base model with auto trans and my brakes are always squeaking!!! It's driving me nuts!!! I took it to the dealership twice. The first time, they said it was normal. The second time, they took the breaks off and cleaned everything off. They were quiet for about 2 weeks and then it started back up again! AAARRRGGGHHH!![xx(]
3 weeks ago I installed brand new ceramic pads in front and I'm still getting the squeak. Now it appears/sounds to be the rear wheels. They're drums back there and I have a lot of pad left on them.
What I can I do to get rid of this annoying squeaking? It's embarrassing to have a car that looks nice, but sounds like crap. I'm at my wits end.[:0]
ANY help or suggestions, would be GREATLY appreciated!!!
Thanks!
Old 27 Mar 2006, 02:55 pm
My 2004 did the same...The rear drums were full of brake dust...Just remove and clean out really good with brake clean...
Old 27 Mar 2006, 03:32 pm
Striker's Avatar
Hello, here is what i have found for "noisy brakes" in Chrysler catalog...
Old 27 Mar 2006, 06:57 pm
my wife had on 01 pt base i could never get the noise to go away forever !! drove me nuts !!
Old 28 Mar 2006, 09:13 pm
Thanks for the help. I guess I'll just have to remove my rear wheels every few weeks and clean out the dust. What a pain!!! If I had only known, I never would have bought my cruiser[V]. My next car will definitely be a Toyota!!!
Old 28 Mar 2006, 09:55 pm
Change the brake shoes and don't use oem shoes
Old 01 Apr 2006, 04:12 pm
Yes it happens. But it does happen on all vehicles. Do you do alot of stop and go? What pads or shoes are you using? Stock or aftermarket?
This is what you can do to get rid of it. Check your rotors and/or drums, make sure you do not have any hard spots or groves from wear. If you do, resurface the rotors and/or drums. If the hard spots are deep replace the rotors and/or drums. Also replace your pads and/or shoes. I recommend Bendix pads and shoes. Why? Better made than many others and lifetime warranty. Never buy pads or shoes again. I know many autoparts sell others and claim to be the best but I have worked in the automotive industry for over 18 years as a brake, suspension and alignment specialist and found the Bendix to be way better made than others. They make an anti squeak pad. Remember to make sure all you moving parts are lubricated so as to not cause any uneven pad wear and or squeak from those moving parts. If any of the rubber gromets are torn or deteriorated replace them. That way you wont have to deal with uneven wear or squeaking. Us the anti squeak shims for your pads. Also replace the hardwear kit in the rear. Remember the springs that hold your shoes in the rear loose thier spring retention because of the daily use and heat produced during breaking. I hope that this helps. I know it is alot of info. Shoot me an email and I will answer any questions you may have. Later[^]
Pete
Old 01 Apr 2006, 06:17 pm
That is not true...I have two Honda Civics a 2003 and a 2004 along with my pt...One civic has 32,000 and the other has 52,000 on it. Both original brakes with drums in the rear...never a peep out of them....It is the old saying...garbage in garbage out...
Old 02 Apr 2006, 11:14 am
You must not drive in town much
04 cool vanila Limited Turbo
Wife has a 03 limited
(Steel Blue)
Old 02 Apr 2006, 11:23 am
I live in the city of Louisville, KY
Close call with the brakes sawdust123 General Turbo Discussions 7 22 Oct 2005 01:13 pm
Brakes, stalling, gas mileage, maintenance emr131 General Turbo Discussions 13 12 May 2005 01:08 pm
New Brakes... matt87951 Tech & Performance Forum 26 27 Apr 2005 02:38 pm
Brakes - Turbo vs GT quicksilverdon General Turbo Discussions 11 16 Mar 2004 10:40 am
Brakes Artemis Tech & Performance Forum 6 14 Jan 2003 11:04 am
