PT Cruiser Forum Car Videos
Jeep Parts | Car Rims
Key Won't Turn in Ignition
Old 28 Mar 2006, 08:12 pm
twobits48 twobits48 is offline
Default Key Won't Turn in Ignition
Anyone have this problem? I have a 2002 PT limited edition. I put the key in the ignition but it won't turn. I have an automatic, so I try to move the gear shift -- no luck. Eventually I can get it to start. I have 2 keys -- tried them both -- still the same problem. Any ideas before I take it to the dealer?
Thanks,
Karen
Old 28 Mar 2006, 10:16 pm
bobs turbo pt bobs turbo pt is offline
hey two bits, when the key is in the ingition and it doesnt turn try moving the steering wheel a little and see it that works
Old 28 Mar 2006, 10:33 pm
Hi Bob, Tried that too, In fact I tried kicking it but that did not work either . What is even stranger is that eventually I get it to turn it may take ten minutes. Thanks for the tip.
Old 29 Mar 2006, 12:42 am
TurboCruiser13 TurboCruiser13 is offline
Send a message via AIM to TurboCruiser13
There's a possibility that the tumblers in the ignition swith have worn out...I've got a company van with 2XX,XXX miles on it that does the same thing...ya gotta kinda wiggle the key around a bit to get it to turn
Old 29 Mar 2006, 04:39 am
Fodder4U Fodder4U is offline
Make sure you don't have a lot of well... crap on your keychain making it heavy. Mopars do not have the best ignition switches and having a heavy chain will shorten the life of it prematurely.
2004 TE Turbo Auto (Silver)
Mopar Stage 1 w/ Mopar BOV, Mopar CAI, 2.5\" Dual Outlet Heartthrob Cat Back Exhaust System, Gold Line lowering springs 1.50\" front and 2.00\" rear and APC Gen II Euro Tail Lights.
Old 29 Mar 2006, 09:36 am
MX-5 MX-5 is offline
Fodder is correct.
I change a lot of ignition switches.
Most always, there's a lot of junk on the keychain.
The PT ignition switch isn't tough to replace.
Of those with 5lbs of crap on their keychain, a majority took some kind of physics classes. When I ask them to imagine the pressure on the switch tumblers with the fulcrum at the end of the key...... they just give a blank stare.
With just 8oz hanging down 3 inches, the pressure on a contact point of .125 sq/in inserted 1 inch past the fulcrum, is an incredible ammount of force. Then you make the weight swing and bounce over bumpy roads .... can you inmagine what that key is doing inside the switch?
Usually, a few hundred dollars for a new switch keyed to their car and replaced, will help educate them on the dangers of large keyrings.
Old 29 Mar 2006, 07:34 pm
wow good points, never thought of the heavy key chain thing !!
vB code is On
Noise in front when making left turn; not right Runkle Wheels, Tires, Suspension 2 12 Feb 2007 01:04 pm
Turn Signals Not Working Indynick General PT Cruiser Discussions 9 15 Sep 2004 02:25 pm
Ignition Questions....need help. spark plugs ptcruzin42 Tech & Performance Forum 5 15 Mar 2004 08:39 pm
Key will not turn relytgerg General PT Cruiser Discussions 11 17 Feb 2004 02:36 pm
key will not turn Beam General PT Cruiser Discussions 25 24 Dec 2003 06:38 pm
  Cheap computers | Mobile Phone | Free Ringtone | Mobile Phones | Coin Community
