engine hesitating
Old 31 Mar 2006, 05:26 pm
Default engine hesitating
My 2005 conv. turbo lite has started to hesitate when having to pass another car and having to put the throttle anywhere from 1/2 to full throttle. My PT now has 19000 miles. Also notice timing ping when car is messing up. I always run Shell Gas because it is "TOP TIER" rated. Notice it above 3000 RPM when the Turbo should be coming on line. Do you think it could be Spark plug wires? I will be taking it to dealer for Oil Change soon. Free oil changes for 36000 Miles or I would do it my self.
Old 31 Mar 2006, 06:35 pm
when the tach is at 3,000 it happens all the time ?? what happens if you stay below 3,000 ?? does it happen then ?? i had a simliar problem with my first 03 gt turbo they never found the problem and they gave me a new car
Old 31 Mar 2006, 06:43 pm
If i stay below 3000 rpm no hesitation, it only happens under hard acceleration after 3000rpm, this problem just started. if i slowly accelerate it does not happen at all. I forgot to add the Check engine light started flashing for about 5 seconds once when i was merging onto the interstate. but the light went out. I call the dealer and they said if the light doesn't come back on don't worry, but since that happened i have noticed the hesitation.
2005 Electric Blue Convertible, turbo lite Tour Edition Chrome belt line and chrome grill.
Old 31 Mar 2006, 08:03 pm
if i was you i would go to the dearlership and take them for a ride !! see if you get any codes to pop up where your mileage is diplayed put the key in the ingition turn it forward then back three times(dont start the car) just all the way forwarded just before its starts , then look where the mileage is it might show a p .... code there write it down and post it someone will help you out with that keep us posted
Old 02 Apr 2006, 11:36 am
Change your plugs. My 04 did the same thing. From what i've read and experienced some PT's will go through plugs every 30000km or so. Mine has 80000km on it and i'm on my forth set. After I got the stage 1 I put in the requested NGK plugs and find I have to change them even more frequently. Good thing they are easy to get at. Haven't found an answer why but I've talked to a few people with the same problem.
04 GT,5spd, Stage 1, Mopar BOV,K&N Intake, Front+Rear Springs, Mopar/borla dual exhaust, Pillar Gauges, 18in Kazera KZ-R
Old 11 Apr 2006, 02:52 pm
The check engine light came on and stayed on. So I took it to the Dealer and they said the number one spark plug wire was going bad so they replaced all the plug wires and spark plugs under warranty. I pick up the car later today and will let you know if that does not fix it. Thanks for everyone's help.
Old 12 Apr 2006, 11:07 am
Betcha that will cure it - for a while. If they put in stock crap, it just doesn't last. I got stumbling on mine and check engine - misfire cyl # 2 - I put in Crane wires and Champion Irridium plugs - runs sweet...
Happened at less than 19,000 miles.[:0]
Old 12 Apr 2006, 01:25 pm
OH MY GOD!!!! What a difference that made. It feels like it did when it was new. The performance must have dropped of gradually that I did not notice it. Now when it gets on the turbo, hold on. Thanks again for everyones help.
Old 12 Apr 2006, 09:14 pm
very cool glad its all better !![8)]
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
Review: $2200 for a NA replacement engine PT Ctown General PT Cruiser Discussions 8 24 Jul 2006 01:08 pm
Engine problem BORICUA Tech & Performance Forum 49 03 Apr 2006 05:15 am
Turbo Engine Replacement Bigphil3232 General Turbo Discussions 9 17 Nov 2004 05:43 am
TSB 1802903: Engine Misfire PTskilla General Turbo Discussions 0 18 Aug 2003 12:13 am
  Recreation 2007 | Travel news | WoW Gold | Jobs search | WoW Gold
